Aficio MPC 3000 Still new toner can't detect
    • 37655
    #16
    Re: Aficio MPC 3000 Still new toner can't detect
    Originally posted by maikel safwt
    There is 2 cases in this problem
    1-if installing a new toner and the machine appear please "insert" the print cartridge and the old one was working good the problem here in the cartridge ship you can change the ship from the old one or in the RFID board
    Using the RFID chip from the old cartridge will allow you to use the machine, but it will continue to display that the cartridge is almost out. The percent used of the old cartridge is stored on the chip.
    • mohan
      • Oct 2013
      • 86
      #17
      Originally posted by tamboknon
      Good day Sirs, I already replaced the toner pump cyan and yellow but still the machine can't detect the new toner or still can't supply to the developer. TIA
      The gears in the dev unit often get stripped on this model. I would check to see if everything is turning to allow toner mixing in the dev unit.
      • tamboknon
        • Sep 2015
        • 62
        #18
        Sir mohan, I already replaced also the dev assy. I just have to wait the RFID I request. TIA
        • Pinokio
          • Apr 2016
          • 8
          #19
          Have you tried forced toner supply? There are some cases in which a little push is needed
          • Mark Bbb
            • Jun 2012
            • 1662
            #20
            It is the nozzle, the nozzle it is...
            • j2shortt
              Learning to speak PCL...
              • Feb 2019
              • 56
              #21
              NAH-ZULL
