MP6001 Dev dumping
  • Pinokio
    • Apr 2016
    • 8
    #16
    Re: MP6001 Dev dumping
    Originally posted by Mark Bbb
    Will it spill developer like that when there is no toner?
    I think the voltage between drum and developer is wrong, causing developer to spill all over...???
    Well based on my experience with smaller machines, yes. Have you checked the toner supply rate? Is it 850?
    • Mad_Coachman
      • 99
      #17
      Originally posted by qbert69
      This is why I have come to DESPISE Ricoh!....parts never reach their yield!
      On the MP6001, and all of the OLDER models that are just like it...exhibit the same damn problem with the Developer unit.
      Anywhere from 1.5 million to 2 million, the dev units start puking developer out the back seals, developer falls on the paper feed units and "takes them out" so that they have to be cleaned and lubricated...the developer is some abrasive nasty shit!...oh yeah...and I do clean/replace the filter on the developer unit!
      The MP6001 is a "Lipstick on a Pig" situation...ricoh changes the color and styling (maybe the system engine so it's a little faster) but underneath, it's the same shit!...same old shit...new day!
      Another "gripe" is the foam gathering rollers on the finisher....FOAM???...for REAL?!...that shit ROTS!!!....how about a flexible rubber that DOESN'T rot?!?!
      NEED I SAY MORE?!
      I TOTALLY AGREE....Especially the "Lipstick on a Pig" remark!!!!
      • Phil Walling
        • Dec 2015
        • 39
        #18
        • Wild Bill
          • Jul 2005
          • 774
          #19
          Phil, How did this go?
          Izzy
          • qbert69
            • Mar 2013
            • 1152
            #20
            WooT!
            Got another "PIG" to deal with! Ricoh Aficio 1060 at a copy shop puking developer out the rear of the developer case, taking out all of the paper feed units so they have to be cleaned and lubed also!....g0dd@mn piece of cr@psh!t Ricoh!!!
            REACH FOR THE STARS!!!
            Konica Minolta Planetariums!
            • Codex
              • May 2008
              • 704
              #21
              Hello
              The "wrong toner" Problem is well known by Ricoh, we had similar problems (dirty copies,light copies) and so on, at the end the problem was the TYPE 9002 Toner...now with the new toner stock the problem disapeared.....but...i had a simlar problem with an MP 6001, after changing developer the customer called for light copies, i opened the Dev unit and surprise there was only 350 gramms (instead of 950) Developer inside the Group......i looked inside the machine but there was no developer around...I think the problem was a faulty potenzial sensor and the quenching lamp (broken connection)
              For the Developer leaking at the rear of the developer unit i found a solution that worked for me, change the bushings with this one : B070 3170
              they have a bearing inside.
              Memento Audere Semper
              • qbert69
                • Mar 2013
                • 1152
                #22
                WooT!
                BTW--the copy count on this machine is/was around the 1.4 million mark at the time of epic fail.
