Screen not going into SP mode properly with SC552!
  • Hadster
    • Aug 2011
    • 264
    When I instruct WAY out of town customer to enter SP mode over the phone this is what comes up and will not go any further into SP mode after they touch copy SP. (See attacted) Door switches, BCU? I'm sure someone has seen this but I can't remember what the cause is! Thanks!
  • Gift
    • Mar 2011
    • 2458
    Re: Screen not going into SP mode properly with SC552!
    Sometimes it's a matter of patience - especially with the newer models: after a cold start you have to wait until you can select a sp group after entering sp mode.
    • Hadster
      • Aug 2011
      • 264
      I agree but I had him wait for a few minutes and still no change.
      • sandmanmac
        • 3979
        A reboot alone may help, but there may be something in the print que?
        Try rebooting system with network cable removed.
        • zed255
          How'd ya manage that?
          • 1024
          Known issue on some models. You may need to update firmware first before you will be able to reset your code.
          • Hadster
            • Aug 2011
            • 264
            I had him disconnect network cable first thing. Zed, I think you may be correct because he updated his computer to windows 10 and was complaining about not being able to scan anymore (gee I wonder why!). This is not my regular customer so I don't know what firmware version he has but I will suggest that he have it done before anything else. Thanks guys!
              • 37357
              Turn the machine completely off. Disconnect the network cable. Open the front door and turn the machine on. Leave the door open until SP mode has been entered. Wait until after all functions have loaded (FAX, Printer, Scanner). If JAVA is installed, wait an additional 5 minutes for JAVA to finish loading.
              One thing to do when telling customers how to clear fusing unit SC codes is to tell them if the code returns then there is a hard failure. Tell them to never clear a fusing code more than once every 30 minutes. Otherwise you are going to end up with melted fusing unit components.
              • copier tech
                • 8132
                He has firmware version 1.70 can this this on your pic!
                • Mark Bbb
                  • Jun 2012
                  • 1662
                  Customar can block service mode, so, you need to ask him for log-in the user tools and set service mode lock to "enable".
                  Might help too...
                  Good luck
