RICOH MPC305 - Heavy Fuser - Grease for Fuser Film
  • DiskCopy
    • May 2011
    • 33
    • 37544
    Re: RICOH MPC305 - Heavy Fuser - Grease for Fuser Film
    The grease Ricoh sells (Barrierta JFE55/2) works but is a bit pricy. You could see if you can find a small tube of Dow Corning Molykote 41. It has a service temperature of 288 Deg C vs Barrierta at 260.
    • Zeldaman
      • Mar 2011
      • 946
      • copier tech
        • 8184
        I replace the sleeve, pressure roller & the 3 gears as a set usually they go about 100k or 2 years
        It if the fuser starts making a "farting" type noise that is time to replace the above parts.
        What you don't want to do is risk the fuser drive gear wearing down, that is a big job.
        • Zeldaman
          • Mar 2011
          • 946
          Hi there!
          After checking the prices for the fuser-parts, we only order the complete fuser, the price is much less.
          Greetings...
          • Polarbear
            • Feb 2012
            • 1070
            Originally posted by Zeldaman
            Hi there!
            Greetings...
            +1
            The complete fuser is cheaper than the parts AND does not take up all the extra labour as well.
            Press the GREEN button!!
            • DiskCopy
              • May 2011
              • 33
                • 37544
                Here is one to try. It is actually for automotive breaks but the specs are right. 500 degrees Fahrenheit is 260 degrees Celsius which is the temperature for Barrierta JFE55/2 that Ricoh recommends and sells for a ridiculous price.
                Amazon also has a number of suitable greases. Just search amazon.com for high temperature grease all departments. They have Molykote 41 and 44 (200 degree C), DuPont Krytox (good but expensive) and many more.
                Amazon.com: Super Lube 97008 Silicone Lubricating Brake Grease with PTFE, 8 oz Tube, Translucent White: Automotive
                • fshead
                  • 2376
                  i think the chemplex is the same lube/grease that they use on the hp 4200/4300 fuser sleaves.
                  • fshead
                    • 2376
                    i use to buy the super lube from my local ACE hardware store,it works but it does dry up over time.
                    any thought on a grease and old style silicon oil mix?
                    i have a few quart bottles laying around from my ricoh 6513 accounts i use to maintain.
                    • rthonpm
                      • Aug 2007
                      • 2859
                      Having used the actual Ricoh grease as well as Chemplex and Krytox, I prefer Krytox. Chemplex just seems too 'goopy', and also leaves a bit of an odour as it first heats up in a machine.
                        • 37544
                        You could try silicon heat sink compound. I use it to pack bearings.
                        • fshead
                          • 2376
                          wow havent heard SHC used in years,
                          many years ago 25 plus on the anaolog minoltas they used triacs for the heat lamps and exp lamps that
                          you could unscrew and change but only if you applied the compound so they would kool off,on the metal heat plate..
                          i can remember people using MOBIL 1 but when it got hot it would stink like a chemical plant.poor customers sitting nearby
                            • 37544
                            This is what I use. https://www.altex.com/GC-Silicone-Di...1-P143181.aspx
                            I used to get it at a local electronics store but they are no longer in business.
                            • Bantams
                              • Jun 2012
                              • 603
                              TIP check the price of the entire fuser units for these its actually cheaper than changing the sleeves
