RICOH MPC305 - Heavy Fuser - Grease for Fuser Film
  • Klydon
    • Mar 2009
    • 243
    #16
    Re: RICOH MPC305 - Heavy Fuser - Grease for Fuser Film
    We have had bad luck on the gears on these. They are basically junk. Ricoh just came out with some new type of replacement gears. I have only put them on one machine and only recently, so I don't know if they will work better/last longer or not.
    I use Krytox for grease.
    In an effort to spare everyone some reading time, I won't go into detail of what I think about this model, but rest assured it isn't good.
    • Gift
      • Mar 2011
      • 2459
      #17
      I also noticed new part numbers for the gears recently but I haven't tested them full cycles. Not shure what went wrong designing this fuser because it basicly works ok beside the fast-wearing gears. Sleeves etc. are no major issues on my end, just the gears. We also install an entire new fuser if the rollers/belt is defective.
      • qbert69
        • Mar 2013
        • 1152
        #18
        This is the grease we use for Hot Rollers and other moving parts in a fuser! (see pix!):
        PS--We've had this can for quite awhile!--It lasts!
        PPS--I've got a film cannister of it in my tech bag and it has lasted!
        REACH FOR THE STARS!!!
        Konica Minolta Planetariums!
        • Larhal
          • 602
          #19
          We use Molykote 44. Real success story.
          Larhal
          Larhal
          If all else fails read the Service Manual!
          If that fails, meet me at the pub and we will discuss it.
          • Gift
            • Mar 2011
            • 2459
            #20
            I generally use no grease at all on fuser gears (with just very few exceptions) just between bearing/hot roller contact surfaces. Many machines runs just fine without messsing around with grease, some seems to need additional lubrication.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              #21
              The grease Ricoh sells (Barrierta JFE55/2) works but is a bit pricy. You could see if you can find a small tube of Dow Corning Molykote 41. It has a service temperature of 288 Deg C vs Barrierta at 260.
              Look up the new fluotribo grease VSSG9002. The price on that stuff is insane!
                • 37550
                #22
                Yeah, I searched it. The only place I found that showed US price for a 100G tube was $412.50. And the specs put it only to 250 Deg C vs. Molykote at 288.
                • fshead
                  • 2376
                  #23
                  wow
                  and i was upset when the cost of a tube of teflon grease went up towards $10 us
                  • Codex
                    • May 2008
                    • 704
                    #24
                    i had a bad problem with an 2051, after i lubricate the fusing film with Barrierta the fuser didnt turn anymore, resulting in paper jams...
                    Memento Audere Semper
                    • copier tech
                      • 8186
                      #25
                      Yes as many others have said cheaper to fit a complete fuser than the sleeve. The gears have been modified so the fuser now goes past the PM life, over 100K cant complain about that for a small desktop model.
