MP C305 firmware?
  • copier tech
    • 8119
    #16
    Re: MP C305 firmware?
    Originally posted by peter_58_ha
    Hello from Germany!
    I know this is an old thread, but is anyone around to provide the latest firmware for my C305SP ?
    Thx and best regards
    Peter
    We can supply you with this firmware file(s) should you still need it.
    Feel free to drop us an email enquiry.
    Kind Regards.
    www.copierfirmware.co.uk
    • gkalman2004
      • 157
      #17
      Hello from Germany!
      Peter
      Yes it is old. Sorry i lose my account from ricoh now 3 years ago when i start to work with toshiba, hp, lexmark,brother.
      gkalman
      • copier tech
        • 8119
        #18
        gkalman
        The MP C305 is still a good model & only recently discontinued.
        • marvin-vegan
          Product specialst support
          • Jan 2021
          • 46
          #19
          I can also provide firmware if you need. Is that allowed on the forum? In PM? Or external link?
          Let me know if you need.
          Btw: for activating Airprint you need four firmwares: System/copy, printer, network support, pdf
          • tsbservice
            Field tech
            • 7937
            #20
            @marvin-vegan Welcome to forum. As for FW I prefer to PM members.
            • marvin-vegan
              • Jan 2021
              • 46
              #21
              Thank you for letting me know. No, problem. I can manage. Just ask.
              All the best
              m.
              • tyvmucho
                • Jan 2021
                • 6
                #22
                Hello, is there anyone willing to share a firmware for this machine with another guy? I'm hoping it will fix my scan to net issues with the latest SMB protocol.
                I currently have
                Module Name Version Part Number
                System/Copy 4.09 D1175437
                Network Support 12.30 D1175430K
                Thanks in advance.
                • copier tech
                  • 8119
                  #23
                  I currently have
                  Thanks in advance.
                  Happy to help. These files are very outdated.
                  Firmware Update - Printer & Copier Firmware
                  • Discipulo1982
                    #24
                    Hola, soy de Colombia, estoy buscando el Firmware de esta maquina, mi equipo no muestra la opcion de impresora en el tablero y tampoco puedo imprimir desde el PC. Estoy muy atento a este hilo tratando de dar solucion a mi equipo
                    • copier tech
                      • 8119
                      #25
                      Hola,
                      Seguro que podemos proporcionarle el firmware que puede resolver su problema.
                      • ossimada
                        • Mar 2022
                        • 2
                        #26
                        Hello,
                        Have a problem starting up the Ricoh mp C305.
                        Tried to update the firmware remotely using Web Image Monitor.
                        It's partially failed and now displaying the following message:
                        Waiting for firmware update data...
                        IPV4 address: XXX.XXX.XXX.XXX
                        Please wait.
                        I cannot enter SP mode. Nothings works. Can ping the device Ok.
                        Anyone can advise if there is any methods to recover the device?
                        • ossimada
                          • Mar 2022
                          • 2
                          #27
                          Hello,
                          Please wait.
                          • Gift
                            • Mar 2011
                            • 2455
                            #28
                            Originally posted by ossimada
                            Hello,
                            Please wait.
                            Can you access the WIM again? If not you might try and run the SD card method or Ricoh Update Tool (wich would probably not work in this case).
                            Once you see the error messagt you try type "Yellow key-1-4-3-C-C-C" to abort a firmware update error/resume (won't work in all cases)
                            • marvin-vegan
                              • Jan 2021
                              • 46
                              #29
                              or <reset> <1> <4> <3> <C> <C> <C> <C> <C> you should hear the "beep" sound, confirms that fw update has been canceled. Then reboot machine, you should be able to get it running to HOME screen
                              • Gift
                                • Mar 2011
                                • 2455
                                #30
                                I think you're right - not shure why I came around with 3 times "c" - does it even do anything?
