MP C305 firmware?
  • marvin-vegan
    Product specialst support
    • Jan 2021
    • 46
    #31
    Re: MP C305 firmware?
    Originally posted by Gift
    I think you're right - not shure why I came around with 3 times "c" - does it even do anything?
    no, you are right. to my my knowledge, most of times tripple "C" is enugh to hear the beep sound. But sometimes it is needed to press it 5 times. That's in my notes, maybe from some ancient times. Just to be sure to press the button enough times
      • 8120
      #32
      Originally posted by ossimada
      Hello,
      Have a problem starting up the Ricoh mp C305.
      Tried to update the firmware remotely using Web Image Monitor.
      It's partially failed and now displaying the following message:
      Waiting for firmware update data...
      IPV4 address: XXX.XXX.XXX.XXX
      Please wait.
      I cannot enter SP mode. Nothings works. Can ping the device Ok.
      Anyone can advise if there is any methods to recover the device?
      It is a safer option to update via SD card. Try this method.
      • Gift
        • Mar 2011
        • 2455
        #33
        Ahh I think there was a code with "5x C" for panel self diagnostig/touch panel calibration (Y1995CCCCC or something like this).
        • hsnslh
          • Feb 2021
          • 10
          #34
          hello,
          I have a printer Ricoh Aficio MP C305SPF and need to update the driver because it shows some errors at starting up like "faulted module websys.mod", and the Web page does not work (getting 404 Page not found error)
          can you PM me the firmware please ?
          It's a personal printer and I need to update the firmware to use the latest features.
          Thank you in advance.
          • rthonpm
            • Aug 2007
            • 2847
            #35
            Originally posted by hsnslh
            hello,
            Forum etiquette is to create your own post instead of tagging on to an old one.
            Sent from my Pixel 6 Pro using Tapatalk
