ricoh mp c4500
  • duplicators
    • Apr 2016
    • 63
    [Dead] ricoh mp c4500
    i have a problem with the lcd i change the green glass and when try to start the machines the lcd doesnt work i take a picture any idea
  • subith
    • Jun 2009
    • 5
    Re: ricoh mp c4500
    [ATTACH=CONFIG]32776[/ATTACH]
    Problem with BICU
    • copier tech
      • 8174
      Re: ricoh mp c4500
      Did you run the calibration after you replaced the touch panel?
      Y, 1,9,9,3 stopx5
      • Polarbear
        • Feb 2012
        • 1070
        Re: ricoh mp c4500
        Hi
        It is difficult to see from the photo - is there any image on the lcd?
        If not re-check that all the cables are correctly re-inserted on the LCD driver board (on the back of the op panel) when you re-assembled the op panel.
        Also check with a torch to see if there is no image on the lcd, as when the backlight lamp fails (or is not plugged into the driver board) you will not see the image on the lcd even if it is there.
        Press the GREEN button!!
        • Greyfox1223
          • 8
          Re: ricoh mp c4500
          Try to check on the web browser for the service call condition....if not try to replace the polygon mirror motor
          goodluck...
            • 37533
            Re: ricoh mp c4500
            Was the back light working before you change the "green glass"? It sounds like you might have not gotten all connectors reconnected properly.
            • tufbnme
              • 493
              Re: ricoh mp c4500
              Second the back light.
              • copier tech
                • 8174
                Re: ricoh mp c4500
                The green glass is just the touch pad I assumed posted had a touch issue not dead LCD screen
