Heys folks, I have a Savin 3535 that is producing a blurred line on the trail edge of the prints when printing on 80lb Cover (216g/m2) {business cards}. The machine has just over 335k, total prints, and the customer states that she has always been able to run this paper using the Thick 1 setting from tray 1. I suggested to her to use the Thick 2 setting and run the paper from the by-pass, which is what the machine calls for. She called me back the next day and said it worked great.
A few days later, she called back saying that it was doing it again, but now it was very random. Out of 100, she noticed that 10 or so would have the blurred line on the trail edge.
I went out today and rebuilt her fuser and found that the tension roller had put a nice crease (or bump, however you want to look at it) on the belt. I told her to run some business cards and see if it helps and if not, then I would come back out and adjust the fuser speed.
What I am thinking of doing is adjusting the Thick 3 setting and have her run the 80lb cover through the by-pass. This will limit the number of prints she can make on the heavy stock, in one setting, as well as allowing her to use the Thick 2 settings as she normally does, with her other paper types.
What do you guys think?
An image sample that I have scanned, so... http://www.copytechnet.com/forums/me...lur-sample.jpg
