RICOH MC305SPF POS Not seeing Yellow cartridge
  • Wbankard
    • Apr 2016
    • 18
    [Misc] RICOH MC305SPF POS Not seeing Yellow cartridge
    OK , I've replaced the toner sensor PCB and cleaned out the copier, Installed OEM toner but it still states reseat the toner.. Problem >> the housing the cartridge goes into at the end, that opens the sliding door for the cartridge , does not close it when removing causing a mess. Question > cause for that ??? next The yellow is not recognized when making contact with the contacts.
  • copier tech
    • 8195
    Re: RICOH MC305SPF POS Not seeing Yellow cartridge BRB PCB D1175162
    If the machine is saying "Toner not set" the most likely cause is the contact for the yellow toner is bent or snapped seen this many times, takes about 90 mins to replace.
    BRB PCB D1175162
    • Wbankard
      • Apr 2016
      • 18
      Understand that has been replaced and the original was not bad
      • ruben
        The New Guy
        • Oct 2012
        • 1204
        If it tries to load the toner after you replace the bottle, then goes back to saying the bottle is empty, then it is a faulty toner hopper. Had a few of these go now, and it is not fun to replace.
        • TonerMunkeh
          Professional Moron
          • 3865
          I've had to change the hopper housing for this fault.
          Hit it.
          • ricmartinho
            • 142
            On the toner hopper there are 2 white plastic pieces on either side that open and close the toner bottle. I've had a few toner bottles that would force one of the pieces to jump out of position and prevent the toner bottle from entering fully into the machine. You can check this easily by removing the laser units and vacuuming the toner hopper entrance. Compare the position of the white pieces with other colors after pushing and pulling the toner bottle slowly. I solved by changing the faulty toner bottle "head" with an used one that works fine.
            It may show the "Independent toner supplier" message but will work just fine.
            • Wbankard
              • Apr 2016
              • 18
              Thank you for your help. I ordered the housing assembly. Get back after I put it in.
              • dotdeas
                Senior Solution Consult
                • Aug 2015
                • 18
                This is a known issue, upgrade to the latest firmware. Else the issue will return even after replacing alot of parts.
                • Wbankard
                  • Apr 2016
                  • 18
                  I am not familiar with the software upgrades. I'm working on this printer for a friend, I'm HP certified not Recoh
                  • dotdeas
                    • Aug 2015
                    • 18
                    Then you need to get the official firmware for the machine from a ricoh dealer.
                    • copier tech
                      • 8195
                      I agree, on this model it is very important to keep ALL firmware uptodate
                      • Wbankard
                        • Apr 2016
                        • 18
                        Thank you all for your help. The problem was the detente in the housing stopping the cartridge from touching the sensor board.
