Mp 4000 developer set up not initialize
  • mrfuser
    • 1607
    Can't get the machine to perform sp2801. Does nothing when hit execute. Machine comes to ready. Any ideas?
  • qbert69
    • Mar 2013
    • 1152
    Re: Mp 4000 developer set up not initialize
    Did you turn off and restart the machine after executing SP2801???
    REACH FOR THE STARS!!!
    Konica Minolta Planetariums!
    • mrfuser
      • 1607
      Yes and when you hit execute nothing happens
      • qbert69
        • Mar 2013
        • 1152
        Is your touchscreen overlay calibrated correctly???
        • LNorris
          • Sep 2008
          • 645
          did you enter the lot number first?
          • mrfuser
            • 1607
            Yes to all
            • Iowatech
              Not a service manager
              • 3930
              Is 2208 set to 1? It should be 0. 1 may indicate a bad TD sensor. If that's the case there should also be recent error codes.
              Along those lines, could you tell us what is listed in 7403 001 and 7403 002 if you have a chance?
              Just a guess, sorry if it is a waste of time.
              • bob marley
                • Jan 2012
                • 1339
                seems like a touch screen problem
                try to perform the ID sensor and see what happen after hitting the execute
                Live for yourself and you will live in vain. Live for others, and you will live again
                • jonhiker
                  • 661
                  if the touchscreen is good, make surethat the firmware is up to date. there was an issuen with dv initialization that was fixed by firmware.
