aficio 551 adf problem
  • aswaney
    • Jul 2025
    i have a aficio 551 out in the field that is putting a solid straight line on the edge of the copy. it only happens on the first copy through the ADF. any ideas
  • schooltech
    School District Tech
    • Jun 2008
    • 504
    Do you know if any adf registration or margin adjustments have been made? Print out the SMC report and see if anything is too far out of adjustment.
    Bachelor of Science in Information Technology, Comptia A+, Comptia Network+
    • aswaney
      i have checked the smc and everything looks ok.
      • cobiray
        Passing Duplication Xpert
        • Mar 2008
        • 1199
        Is it the lead edge of the page? How are the edge erase settings? Is it from all trays? LEF and SEF?
        • aswaney
          it is the leading edje of the page. it happens out of every single tray. i rsaw somewhere that it could be the adf board i think that i saw it in a tech bullentin.
          • cobiray
            • Mar 2008
            • 1199
            Forgive me if you've done this, but have you replaced the feed components, reverse roller & torque limiter? Cleaned the non reflectors and paper path sensors?
            I only found one TSB on the ADF.
            • xeroid
              Document Technologies Pro
              • 148
              Rainex is not just for your windshield
              fold a piece of paer in half. squirt a little from the smallest 2 dollar bottle of rainex you can find at the auto parts store. spread it all over and fan for 1/2 minute to dry and polish with the same paper. Fixes lots of reg problems on the big belt digitals. An Af 551 operator taught me this trick
              • Scott_Lewis
                • Mar 2007
                • 519
                I just use 6 drops of light machine oil and spread it on the glass until I see more oil streaks.
                • paulg
                  • Jun 2007
                  • 278
                  As well as a oil or polish on the platen glass (also make sure the glass is up the right way)
                  I open up the area where paper feeds on to the platen glass.
                  With a puffer brush puff out all the paper dust and gunk i can. Clean up the transport rollers.
                  As well as cleaning the sensors in the feed area and feed tyres.
                  Problem is solved in many cases.
                  Also check the drive of the df unit that clips out is not spliting or even worse another engineer has performed a bodge job on it. part
                  B301 2242 Shaft
                  • FRIDGEMAGNET
                    • Aug 2007
                    • 377
                    On this ADF the original is fed onto the glass ond then reversed onto the scale. If the ADF is not butting it up correctly this would give a line.
                    I once had a problem like this and it turned out to be someone had replaced the ADF PCB and not done the ADF auto speed adjustment.
                    • Fearless V K
                      • 620
                      If the first copy off the glass also does the same thing, then the scanner pulley set screw could be either loose, missing or broken.
                      Don't take that toner with me!
