duplex line on second side mpc5501
  • digicor
    • Jul 2008
    • 1153
    I have line on the second side ONLY horizontal, COPY ONLY not in the print??? I can move the line with leading edge registration but its 9mm ( see attached) and it ruins the rest of the page, nothing else moves the line, can someone tell me how to clear this up? i have cleaned the transfer roller, for some reason this worked on one before, How is this solved? its obviously in the scanner
  • PJB
    • Apr 2015
    • 19
    Re: duplex line on second side mpc5501
    In User Tools, copy feauters, edit: clear front margin, back margin and 1-sided to 2-sided auto margin. Can do the trick
    • logrady2331
      • Feb 2011
      • 301
      SP mode 6 (periphs) Reg. adjustment, side two, set to negative 3.0 or 3.5,. Done. Very common.
