mpc3003 curling paper
  • Mark Bbb
    • Jun 2012
    • 1662
    Hi,
    At the first time I upgrade the firmware, that was a one moths ago, and the problem went away.
    But now its back...
    Yes, the paper is moisture due to the much rain we have the last few days here in Belgium, but even than it might not curl so strongly.
    And... i know it is an issue with these models...
    So, i would be thankful if you can help us.
    Greetings,
    Mark
  • Zeldaman
    • Mar 2011
    • 946
    • tonnerboy
      • May 2011
      • 212
      Re: mpc3003 curling paper
      Hi.
      The suggestion given by Zeldaman is the workaroud (in my point off viewe).
      Anyway in some extreme cases i recomend the customer to buy a Tray heater. And than the problema is solved.
        • 37556
        Bulletin issued 7 April 2016 has the part numbers for the 120V machines. Check your bulletins for Europe to see if there is on for the 200 Volt
        machines.
        rfg071159.pdf
        • copier tech
          • 8192
          In Europe (UK) we have this little option for curling!
          RD147127a.pdf
          • Counsel
            • Aug 2011
            • 529
            If the problem is that the paper is curling into a ball in the exit bin there are different idle rollers that can be installed in the exit assembly that keep paper from doing that, i had to install them on almost all of our 2003/2503 models.
            Edit "copier tech" posted the TSB i mention just above me. doh
