How to Clear this massage on Ricoh MPC
  • xlbizs
    • Jun 2009
    • 66
    #16
    Re: How to Clear this message on Ricoh MPC
    Yes, work after remove those files. ps option working. will try MAC PC to try print.
    Thanks all.
    • sturmtrooper
      Copier Combobulator
      • May 2016
      • 587
      #17
      Re: How to Clear this massage on Ricoh MPC
      Does it actually WORK or is it just not complaining anymore?
      • xlbizs
        • Jun 2009
        • 66
        #18
        No. (Message gone only), just try to print from PC & Mac. the 5501A will resetting the job after few second receiving the data. still trying how to show this issue.
          • 37652
          #19
          You now basically have a mostly blank SD card. You need to get a new PS card that has not been used in another machine.
          • fredsp
            Product Specialist
            • Sep 2009
            • 14
            #20
            remove your DOSS SD card
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              #21
              We have a stack of old java, PS, printer cards etc at the shop, I whipe em, peel the label off, and use them for firmware updates.
              • Iowatech
                Not a service manager
                • 3930
                #22
                Me too! They always work after all. I've found it doesn't hurt to have four of them on hand, how many do you usually carry?
                  • 37652
                  #23
                  I have found that due to their capacity they are good for one or two firmware modules only. Most of them are either 64 MB or 128 MB. I like to use a 500 MB or 1 GB for older models and a 2 GB for all the newer models.
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    #24
                    The java one I have is about 512mb. Which is fine for me, the whole thought of putting firmware for different machines on the same card gives me the heebie jeebies even if it's supposed to be fine.
                      • 37652
                      #25
                      I never put more than one machine on a card at a time. What I have encountered is that with some of the newer models, you cannot fit all the modules for single machines on anything smaller than 256MB and if you want to also load the package firmware on the same card, 512MB is the minimum that will work.
                      • copier tech
                        • 8237
                        #26
                        I do this too, I also remove the security encryption cards too, but again they are only 120mb so only good for older machine firmware.
                        What exactly is the security encryption unit card for anyway!?
                          • 37652
                          #27
                          [ATTACH=CONFIG]33283[/ATTACH]
                          Encrypts all files stored on the MFP so that anyone wishing to open them will need the encryption key.
                          • MitchD
                            • Oct 2012
                            • 164
                            #28
                            Originally posted by francisco
                            there are 3 (GPS,gwinit.d,module)
                            Gps is empty
                            open gwinit.d delete all datacrypto files(3) and zoffyx files(3)
                            open module and delete datacrypto files(3)and zoffyx files(3)
                            I used this method on a MPc4501 and it worked great. Thanks!!!!
                            "Heavy music to the normal ear is nothing but a loud annoyance. Most people think of it as obnoxious, talentless music but to someone who really listens and is really in love with music knows how beautiful and amazing it can be" Tommy Rogers of Between The Buried and Me"
                            • sturmtrooper
                              Copier Combobulator
                              • May 2016
                              • 587
                              #29
                              But did the post script option still work after? My bet is that it didn't. Ricoh wouldn't make it that east to remove the protections.
                              • MitchD
                                • Oct 2012
                                • 164
                                #30
                                Yes it did. This method cleared the message and also allowed PS to work. I confirmed using the PS driver on my work PC (Win7 Pro 64 bit) and my personal Macbook (os 10.7 - need to upgrade the poor guy) to print.
