Ricoh MPC 3502 wont line adjust
  • semi
    • Sep 2008
    • 195
    [CQ] Ricoh MPC 3502 wont line adjust
    MPC 3502 wont line adjust,acc all over the place,tried new belt,complete transfer unit.itb motor,IOB,still the same,swopped over pcu's from good copier-still wont adjust,turned off process control-still the same-any ideas?
  • Zeldaman
    • Mar 2011
    • 946
    • rednecktech
      • 54
      Re: Ricoh MPC 3502 wont line adjust
      There may be something going on with the laser or the values for the laser may be out of whack.
      • semi
        • Sep 2008
        • 195
        Forgot to say changed the ID sensors,might order all the colour devs
          • 37532
          I do not see cleaning of the Image Density Sensor Assembly.
          • mikadonovan
            • May 2008
            • 2931
            Not completely sure about this model, but on the C4502 you must input the new coefficient values provided with the new id sensor assy (sp3362-13, 3262-16)
            NEVER ASSUME ANYTHING
              • 37532
              Same with this model
              • semi
                • Sep 2008
                • 195
                Cheers for al the input,I don't normally ask for help,all have tried all,forced toner etc,asked fellow techs,just looking beyond the box....
                • sandmanmac
                  • 3981
                  The few times I've had this issue on other models (haven't needed it on an 02 yet), I've always had success when I run what I call the "advanced line adjustment". I was given these extra steps a few years back on this site when I had the same problem as you describe.
                  Hope it helps.......
                  ***Resetting ACC is that the calibration is written on top of the last calibration over and over. Therefore it becomes corrupt at some point, so the factory recall sets it back to default so you get a fresh start.
                  - ACC Recall SP5-610-4
                  - ACC Recall SP1-101-1 in Printer SP
                  - Process Control SP3-011-1
                  - Process Control Result SP3-012 -> 11111111 (Eg: 11(Y)11(C)11(M)11(K)
                  Note: * Anything other than ‘11’ indicates a problem
                  - Line Adjustment C SP2-111-3
                  - Line Adjustment A SP2-111-1 Execute twice
                  - Printer Test Page SP1-103-2 in Printer SP
                  • Iowatech
                    Not a service manager
                    • 3930
                    I don't work on anything that new, but that sounds a lot like someone did an all memory clear.
                    At least that's almost exactly what happened when I committed that idiot maneuver the first and only time back in the day.
                    As I'm not sure, I'll let the people more familiar with that model tell you whether this could be the case, and what to do about it.
                    Sorry if this was a waste of time.
                    • semi
                      • Sep 2008
                      • 195
                      Re: Ricoh MPC 3502 wont line adjust-Solved!!!
                      Fitted new ITB Unit complete,worked like a dream!
                        • 37532
                        Ricoh has had problems with the belt slipping and causing line adjustment problems.
