Ricoh MP 171 SPF Firmwarefiles and how to upgrade the Firmware?
  • pingpong
    • Aug 2016
    • 32
    #31
    Re: Ricoh MP 171 SPF Firmwarefiles and how to upgrade the Firmware?
    Hello Experts,
    my two Problems are solved!
    1. The Scan2Folder Problem was Solved with Network Firmware 1.07 and works perfektly under Windows 10
    2. The 2nd Problem with some Firmware Upgrade like Scanner, Printer and the E44 "Download Error" was a Problem
    with the write Protected SD-Card in Slot 1. I changed the "write protection Switch" on the Card to the other
    Position and checked the Firmware Upgrade again, it works!
    Thanks to ALL they helped me in the Past! Maybe some other User have the same Problem in the future. Some
    Files are stored in the Flashrom and i don't imagine, some files are stored into the SD-Card in Slot 1.
    On the other side, I'm a little bit sad about a unknown user, that take away my "Rep Power" Today. I see a
    Notification that another user was upset about my stupid questions. By this way, english is not my mother
    language, it's really bad. I want to invite these anonymous user to write in german language. But in all internet
    forums at least one stupid User.
    Best regards from Germany
    Michael
    • Vistec
      #32
      good day all
      we have just up dated to winders server 2012 r2 and windows 10
      but our Richo MP171 needs a firmware update
      dose any one has it or can tell me where to get it
      I notice under the web unit for the printer there is an area for firmware update
      I just require the firmware
      thanks
      • davel
        • Oct 2011
        • 1105
        #33
        Originally posted by JUANOSPINA
        Venta firmware ricoh jucosar@gmail.com
        3 years late replying to this dead thread
        • Foxl26
          • Jan 2024
          • 2
          #34
          Hi Experts,
          i know this thread is from 2016, but i have a Problem with an old printer.
          it the MP 171 i got to use. But i dont have any chance to use scan2folder because of SMB Version.
          So my question is, is there any one who can give me the latest firmeware update?
          My dealer tells me it makes no sense and want to sell a new printer, but as long as its running, i would like to test the latest update first.
          Could it be possible to get some help? Itried my luck, but in that case google is not very helpfull
          Thank you in advance for every feedback
          Firmware-Version
          Modulname Version Teilnummer
          System/Copy 1.00.1 D0675530B
          Network Support 9.02.1 D0675526B
          Fax 01.00.00 D0675528B
          RemoteFax 01.00.00 D0675524B
          Network DocBox 1.00 D0675525A
          Web Support 1.04 D0675527B
          Web Uapl 1.04 D0675529B
          Scanner 01.04 D4685525B
          RPCS 3.9.1 D4685526
          Font EXP 1.06 D4685527
          Option PCL 1.01 D4685528B
          OptionPCLFont 1.04 D4685529
          Printer 1.00 D4685540B
          GWFCU3-17(WW) 02.00.00 D0685570B
          Engine 0.15:04 D0675540B
          Firmware-Version
          RPCS 3.9.1 D4685526
          • Saturn
            • Nov 2023
            • 171
            #35
            Just download and execute the Ricoh Firmware Update Tool. You do not need to get a single Firmware if you use this tool.
            I don't care about who your father is, as long as I'm fishing here, you won't walk on water.
            • Foxl26
              • Jan 2024
              • 2
              #36
              Thank you for the answer.
              I forgot, i also tried to update with ricoh update tool v.1.9.0 in in the network environment.
              But this will not work. it says it needs the latest firmware, begins to download (about 2seconds) and then it says completed.
              But the software version is still the old one.
              I also tried just to download the software update, in the local folder, i just get 2 xml files. no update
