MPC3000 sc 565
  • digicor
    • Jul 2008
    • 1150
    MPC3000 sc 565
    Code
    565
    Description
    Heating lamp consecutive full power 3
    When the fusing unit is not running in the ready condition, the pressure roller-fusing lamp keeps ON full power for 120 seconds or more.
    I have replaced the fuser with another one and it still throws this code the lamp is not broken, any suggestions?
  • bob marley
    • Jan 2012
    • 1339
    Re: MPC3000 sc 565
    Replace the PSU.
    Live for yourself and you will live in vain. Live for others, and you will live again
    • sandmanmac
      • 3963
      Re: MPC3000 sc 565
      Originally posted by bob marley
      Replace the PSU.
      x 2
      Had this just a couple of weeks back, and a PSU resolved it, after fuser replacement didn't
        • 36796
        Re: MPC3000 sc 565
        If PSU does not correct it, check harness from the PSU to the fusing unit. Also check the machine side connector for a bad pin. I had a Pro 1107EX where the tab on the connector that held the contact pin in place had broken and when the fusing unit was inserted, the pin pushed back in the connector and did not make proper connection.
        • digicor
          • Jul 2008
          • 1150
          Re: MPC3000 sc 565
          Thermal fuse under the pressure roller (there are two together) one was popped one was not, hmmmm so far this has settled it, we will see after today , but so far it would seem to have been the problem....
          • sandmanmac
            • 3963
            Re: MPC3000 sc 565
            In your initial post you said that you had replaced the entire fuser without success
              • 36796
              Re: MPC3000 sc 565
              Most likely did not replace with a new fusing unit.
              • digicor
                • Jul 2008
                • 1150
                Re: MPC3000 sc 565
                I did , im wondering if the machine blew the thermal somehow again? but i just re started it after sitting for 3 hours and it comes right up, coincidence?, just weird , Not sure,
                but its working now.
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Re: MPC3000 sc 565
                  The thermopile can also cause this issue.
                  Hit it.
                  • digicor
                    • Jul 2008
                    • 1150
                    Re: MPC3000 sc 565
                    still good after a few restarts
                    thanks guys
                      • 36796
                      Re: MPC3000 sc 565
                      thanks guys
                      With an open pressure end end thermofuse/thermostat, the machine will power up fine as the pressure roller end needs only come up to 50C to come ready. Enough heat will reach the pressure roller end thermistor from the hot roller and the pressure center to reach that. It will code during long copy/print runs as the temperature will start to fade. After replacing anything on a fusing unit, I always turn power on with the door(s) open. I can then enter SP mode and monitor fusing temperatures as it heats. If either pressure reading is slower coming up than the other readings, a fuse/thermostat is open or a lamp is bad.
