error
  • Orion2010
    • Jun 2015
    • 176
    error
    IMG-20160822-WA0000.jpgI replace toner but now show this error
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: error
    Make sure the toner is making it into the development unit. Just had to swap development units on a 4002 because the machine snapped the drive gear off the development mixing augur. No toner in, no toner out!
    • ruben
      The New Guy
      • Oct 2012
      • 1203
      Re: error
      Make sure you haven't left any caps from the old toner bottle inside the machine, and check that the toner hopper handle hasn't broken or come loose.
      Otherwise, you will be looking at a new dev unit and fresh dev.
      • Oze
        Ricoh Fanboy
        • Jul 2008
        • 1663
        Re: error
        Are you a tech or an end user?
        I had one of these with the same fault a couple of weeks ago and it turned out to be the ID sensor.
        Changed the sensor,added toner to the dev ,ran a few sky shots and they're back in business.
        That was on an MP5002.
        If it's one of the smaller B/W then +1 for what Ruben said.
          • 37489
          Re: error
          You failed to supply the machine model. This is very important since the cure can vary by machine.
          • tufbnme
            • 493
            Re: error
            What ever happened to diagnostics?
            • Oze
              Ricoh Fanboy
              • Jul 2008
              • 1663
              Re: error
              I had to edit my original solution for him coz I was totally calling end user....still my sneaking suspicion btw
              • Polarbear
                • Feb 2012
                • 1070
                Re: error
                +1 on the toner auger - similar symptom on an MPC recently - turned out to be toner auger broken clean off drive gear.
                Press the GREEN button!!
                • sturmtrooper
                  Copier Combobulator
                  • May 2016
                  • 587
                  Re: error
                  Same week I had a 2851 that had worn out the development roller gears so badly they wouldn't turn the gears on the development augurs. Same problem and same result, no toner in, no toner out.
                    • 37489
                    Re: error
                    Still waiting for the model so we don't keep barking up the wrong tree.
                    • keithxxiii
                      Just a tech
                      • Nov 2014
                      • 469
                      Re: error
                      this happens for Black and White MPFs,
                      the bottle chuck is closed that is why toner is not loaded on the development unit.
                      and there you go!
                      Aye! Cut the crap
