Mpc 305spf j018
  • catgoldfish
    • 70
    [Jamming] Mpc 305spf j018
    Hey all
    Have an Mpc305 spf giving me some grief. Constant J018 jams meaning the Fuser entrance sensor. Have check sensors in sp58xx all toggling 1 to 0. Paper jams right by the itb unit and transfer roller. Replaced fusing unit, itb unit and entrance sensor. Jams from all two cassettes as well as bypass. Looks like itb unit is not turning. Put dot on end of belt tried to make a copy and jam. Cleared jam looked at itb and dot hasn't moved. Anyone experience anything like this? Going to open back to check the drive area next. Any input would be great.
  • banginbishop
    grumpy old git
    • Oct 2007
    • 894
    Re: Mpc 305spf j018
    Originally posted by catgoldfish
    Hey all
    Before stripping out the drive have you tried output mode?
    Incontinentia Buttocks
    • catgoldfish
      • 70
      Re: Mpc 305spf j018
      Yes i tried the itb motor hi and lo. I can hear the motor turning but no itb belt turning. Was cheating the door open. Sp5804-022 and 023.
      • banginbishop
        grumpy old git
        • Oct 2007
        • 894
        Re: Mpc 305spf j018
        Sounds like you have no choice - you've tried a new unit, output mode etc looks ok.
        Stripped one down a few years back but I don't envy you - good luck.
        just a thought - does it have any image on the belt at all? Eg you do a sky shot or calibration?
        • catgoldfish
          • 70
          Re: Mpc 305spf j018
          Well nothing comes out cause of the jamming but i can see small 1/4 inch wide strips of all 4 colours when i remove the itb. Thats all that it puts on there. I think it puts it on there to start the rotations but the belt doesn't move. I know it looks like a lot of work. I've done the toner hopper mods a few times on this model and it takes a half day. Im sure its the same with this area.
          • banginbishop
            grumpy old git
            • Oct 2007
            • 894
            Re: Mpc 305spf j018
            any relevant sc codes logged? But it sounds like the drive is turning, either a gear has come off or shredded to stop the belt turning.
            let us know what you find out.
            • catgoldfish
              • 70
              Re: Mpc 305spf j018
              No relevant codes pertaining to my issue now. There were codes sc899 and others like that. I will let you know what happens. The model thankfully has been discontinued but I have so many of them. Very bad and not tech service friendly.
                • 36857
                Re: Mpc 305spf j018
                FYI, J018 is not a fusing entrance jam. It is a Relay sensor late jam.
                • copier tech
                  • 8103
                  Re: Mpc 305spf j018
                  Before you spend ages stripping the machine have you tried updating ALL the firmware? firmware can fix all kinds of faults on these little 305's!
                  • catgoldfish
                    • 70
                    Re: Mpc 305spf j018
                    I pretty sure it's fuser entrance jam. I know this is a different model but most jam codes are the same for most machines.
                    • catgoldfish
                      • 70
                      Re: Mpc 305spf j018
                      Will do. Thanks!
                        • 36857
                        Re: Mpc 305spf j018
                        http://www.copytechnet.com/forums/ri...1-018-jam.html
                        But not all machines. My first reply was based on what is in the service manual.
                        • catgoldfish
                          • 70
                          Re: Mpc 305spf j018
                          Ok. I will look at the relay sensor area. Thanks.
                          • gkalman2004
                            • 157
                            Re: Mpc 305spf j018
                            I have this issue and for me was the blocked ball bearing ae030056 after i changed no more jam occur.
                            • catgoldfish
                              • 70
                              Re: Mpc 305spf j018
                              Hi there which ball bearing? Location?
