Mpc 305spf j018
  • gkalman2004
    • 157
    #16
    Re: Mpc 305spf j018
    Originally posted by catgoldfish
    Hi there which ball bearing? Location?
    Inside in the fuser PRESSURE ROLLER (AE020204) -> ball bearing (AE030056) if you have a bad ball bearing the paper move too slow and your sensor detect time out.
    • copier tech
      • 8164
      #17
      Re: Mpc 305spf j018
      The poster replaced the fuser unit!
      • gkalman2004
        • 157
        #18
        Re: Mpc 305spf j018
        I write about my 305 jam problem and i did not know if the poster replaced or not the fuser
        • copier tech
          • 8164
          #19
          Re: Mpc 305spf j018
          How can you give a solution without first reading the posters issue!?
          • gkalman2004
            • 157
            #20
            Re: Mpc 305spf j018
            Read again please i write about my particular fix for j018 and i answer a question about what i changed.
            I don't give any solution, i just mentioned another viewpoint like something blocked or spinning hard.
            • catgoldfish
              • 70
              #21
              Re: Mpc 305spf j018
              Hi all
              Went back to this machine this morning and removed the rear area. Found a lot of loose cyan toner. The problem was the main drive unit. The belt that drives the itb unit fell off. It came off because the plastic free wheeling pulley that puts tension on the belt was worn so bad the belt falls off. Hope you can make sense of this. Ordering new main drive unit. Having problems uploading pics. Email me if you need pics
              • gkalman2004
                • 157
                #22
                Re: Mpc 305spf j018
                Hi all
                If you found the cyan toner you need to "cut the sponge" in the hooper first and you can clean up the main drive unit.
                I make this 2 times for now and i not changed the drive unit, i just clean up the electomagnetic clutch-es from the main drive unit.
                  • 37514
                  #23
                  Re: Mpc 305spf j018
                  But did you most likely did not read all posts in the thread to know what had already been done.
                  • gkalman2004
                    • 157
                    #24
                    Re: Mpc 305spf j018
                    Yes you are right i'm sorry for that, (i read all just i forget about) but maybe it matters if i try to be helpful ??
