Mpc 305spf j018
Re: Mpc 305spf j018
How can you give a solution without first reading the posters issue!?Let us eat, drink, and be merry, because tomorrow we may die!
Re: Mpc 305spf j018
I don't give any solution, i just mentioned another viewpoint like something blocked or spinning hard.Comment
Re: Mpc 305spf j018
Hi all
Went back to this machine this morning and removed the rear area. Found a lot of loose cyan toner. The problem was the main drive unit. The belt that drives the itb unit fell off. It came off because the plastic free wheeling pulley that puts tension on the belt was worn so bad the belt falls off. Hope you can make sense of this. Ordering new main drive unit. Having problems uploading pics. Email me if you need picsComment
Re: Mpc 305spf j018
Hi all
If you found the cyan toner you need to "cut the sponge" in the hooper first and you can clean up the main drive unit.
I make this 2 times for now and i not changed the drive unit, i just clean up the electomagnetic clutch-es from the main drive unit.
before4.jpgafter3.jpgComment
Re: Mpc 305spf j018
But did you most likely did not read all posts in the thread to know what had already been done.Comment
