mpc6003 pcu problems
  • coolcat467
    • Feb 2014
    • 10
    [CQ] mpc6003 pcu problems
    Hey all,
    I have an MPC6003 that just spews black toner everywhere in the machine. Wondering if anyone else has had this problem?
    I am getting way below PM target for the black PCU...129k or so
    Here are some images of the black PCU...
    I am assuming these issues are related....
    Thanks for any and all help you can provide!
  • copier tech
    • 8192
    Re: mpc6003 pcu problems
    Are you running the machine on Genuine Ricoh toner?
      • 37556
      And genuine Ricoh drum units. Are the drum units new or rebuilt?
      • copier tech
        • 8192
        There are no rebuilds available for the metis, unless China have started machine them?
        • coolcat467
          • Feb 2014
          • 10
          Yep, I work for a Savin dealer so all parts are OEM
          • Elmo
            • Feb 2010
            • 541
            Are they feeding just plain paper or using other materials
            what is the location like is it a clean office or dusty environment
            I Used To Live To Fix Things Now i Fix Things To Live
            • francisco
              • Nov 2009
              • 168
              hiyou must see if the pressure of lubricant bar is in exact place (for mpc3003 the pressure is diferent and the pcu is the same)
              • coolcat467
                • Feb 2014
                • 10
                The machine sits in a clean school office. The only stuff they run are various colors of 20lb paper and some cardstock occasionally.
                • coolcat467
                  • Feb 2014
                  • 10
                  Yea, the installation procedure talks about the spring that you have to release for the D149/D150.
                  I did that.
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    It looks like they are running sandpaper through the machine! Unless that white stuff is lubricant from the lube bar.
                    • Brianneoe
                      • May 2015
                      • 322
                      Check your wast toner coil unit. There are some conversations on ricoh's tech forum concerning this issue.Is the waste toner bottle missing the actuator?
                      • Iowatech
                        Not a service manager
                        • 3930
                        I don't work on anything that new, so please take this for what it is worth.
                        Still, if I interpret the pictures you shared here correctly that drum is done as is most likely any seals in the PCU, so that needs to be replaced.
                        Well, at least replacing that PCU would be the first thing I'd try if I had seen that.
                        Thanks for the pictures! Good luck!
                        • tjvincent
                          • 280
                          I would try replacing the DEV unit with the PCU
                          • Sashko
                            • Oct 2009
                            • 110
                            We have same problem on one MP C2003SP, see pictures.
                            Quality of printing is good.
                            • Gift
                              • Mar 2011
                              • 2459
                              Drum on monochrome series xxx4 looks pretty similar after a while - sometimes it won't affect the quality much but sometimes the charge coller causes lines. I want the old series back lol
