MP 301spf auto reduce received fax pages?
  • mrfuser
    • 1617
    Have a client that needs to have the received faxes print onto a single letter size page. It seems to keep splitting it up. I have searched the manual and parameter settings and don't see a simple way to do this. I must be missing something. Any help is appreciated!
    Thanks all!
    K
  • sturmtrooper
    Copier Combobulator
    • May 2016
    • 587
    Re: MP 301spf auto reduce received fax pages?
    Are the faxes they are receiving starting out on legal size paper?
      • 37386
      If the faxes were multiple pages to begin with, then it will be printed as multiple pages. The sending machine sends an end of page code after each page.
      • mrfuser
        • 1617
        Thanks, I do understand that. What I saying is if it receives a legal page how do we get it to print to letter size?
        • KenB
          Geek Extraordinaire
          • Dec 2007
          • 3944
          I don't think what you are looking for is possible.
          That's just too much reduction.
          I'm fairly sure the limit is 10%. Legal to Letter is 27% if I remember correctly.
          I could be wrong. It's happened B4.
          • NeoMatrix
            Senior Tech.
            • 3513
            Is the problem coming from one particular outside fax machine ?
            If so, does the sending machine require a good clean an service?
            Could be a scan multi feed issue causing extended page lengths on send.
              • 37386
              I don't know about the MP 301 but on older machines that I have worked on, it automatically reduce to fit on letter size. You might want to check if there is a parameter for auto fit to paper.
              • mrfuser
                • 1617
                That is exactly what I'm talking about I just cannot find the setting
                • TonerMunkeh
                  Professional Moron
                  • 3865
                  Hit it.
                  • mrfuser
                    • 1617
                    Very sad if you have to go through all that gibberish just to auto reduce! Ricoh wisdom at work once again!
                    nearly every other machine out there is a quick user admin change but not Ricoh eh?
                    wow
                    • mrfuser
                      • 1617
                      Looks like a fax server is sending a doc that is just a few inches longer than letter and it splits it on two pages
                        • 37386
                        I wonder if it is sending metric
                        • mrfuser
                          • 1617
                          Maybe, is there a fix for that?
                            • 37386
                            They could try receiving to the document server and viewing/print using WIM or fax forwarding email or folder.
                            User Tools
                            Facsimile Features
                            Reception Settings
                            Reception File Settings
                            • teebee1234
                              • 1670
                              try these bit switches...
