Ricoh 4501A Fax Receive Problems
  • Yumann
    • Sep 2016
    • 16
    Dear All,
    I have been a lurker on here for a while and have been using the very informative information. I would like to thank all in advance.
    As above I seem to be having problems receiving faxes. I have turned of the ECM and it made a bit of a difference.
    Can someone provide me with a service manual for the above printer for the relevant bits to adjust.
    I want to slow it down to RX speed to 14400 but do not now the bits to adjust.
    Is there any other settings that I can make to ensure better receptions. eg
    Initial TX modem rate - set to 14.4
    Initial RX modem rate - set to 14.4
    PABX equalizer - set to high (both tx and rx)
    PSTN cable equalizer - set to high (both tx and rx)
    Reconstruction time - set to 12s
    Can you the bit to adjust
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh 4501A Fax Receive Problems
    Apparently the MPC4501 has an auto speed step-down system to make sure the transmission has the best possible chance of sending. There are no speed settings in the UP's that I can find. Have you connected a normal phone to the line to check for noise? Is the machine using the correct fax lead?
    Hit it.
    • Yumann
      • Sep 2016
      • 16
      Correct fax lead? I just found one that fitted is there a specific one.
      I'll will check for noise on line. I take it that's a telecom provider issue.
      Thank.
      • TonerMunkeh
        Professional Moron
        • 3865
        Yes, there is definitely a specific one. The part number is 11758X. Yes, any noise on the line will be a telecoms provider issue.
        Hit it.
        • Yumann
          • Sep 2016
          • 16
          Thanks.
          I have noticed the fax issue comes from one source/online fax provider.
          I'll give the suggestions above a shot.
          Thank again.
          • mikadonovan
            • May 2008
            • 2931
            This may help. This is for a C4501, type c5000 D393 fax option.
            NEVER ASSUME ANYTHING
            • anothertech
              • 1757
              That part number doesn't work in my system. What is this lead your talking about?
              • Yumann
                • Sep 2016
                • 16
                Can someone confirm that the bit setting for the ECM for fax on the MPC3001 same as the MPC4501A.
