Dear All,
I have been a lurker on here for a while and have been using the very informative information. I would like to thank all in advance.
As above I seem to be having problems receiving faxes. I have turned of the ECM and it made a bit of a difference.
Can someone provide me with a service manual for the above printer for the relevant bits to adjust.
I want to slow it down to RX speed to 14400 but do not now the bits to adjust.
Is there any other settings that I can make to ensure better receptions. eg
Initial TX modem rate - set to 14.4
Initial RX modem rate - set to 14.4
PABX equalizer - set to high (both tx and rx)
PSTN cable equalizer - set to high (both tx and rx)
Reconstruction time - set to 12s
Can you the bit to adjust
