Sc549-000 mpc4502
  • mrfuser
    • 1617
    Sc549-000 mpc4502
    Replaced sleeve assembly and now we get sc549-000! One page works fine but multiples pops the code.
    any ideas?
    reset fuser in service mode by the way and yes we swapped the fuse.
  • bob marley
    • Jan 2012
    • 1339
    Re: Sc549-000 mpc4502
    check hp sensor home position
    Live for yourself and you will live in vain. Live for others, and you will live again
    • teebee1234
      • Jul 2008
      • 1670
      The replacement sleeves for this model have a high defective rate. Usually one of the fusing lamps filaments is open, allowing one lamp to energize with just enough heat to come to ready. But one print is enough to throw the temp out of range.
