C5503 address book
  • mikadonovan
    • May 2008
    • 2931
    C5503 address book
    Hi, All. I just got a c5503 in, and using the WIM when I click on "add user" in the address book I get a "404 not found" error. Printer config page shows the HDD exists, and the machine has been reset in factory mode sp5846-46. Can anyone shed some light on why this is happening?
    NEVER ASSUME ANYTHING
  • guitar9199
    • Sep 2016
    • 1100
    Re: C5503 address book
    Have you tried using a different browser?
    • mikadonovan
      • May 2008
      • 2931
      Yes, Chrome and Firefox. I can log into the wim just fine and make changes just like always, except when I click "add User" in the address book. As far as I can tell, administrator authentication functions are Off.
      • KenB
        Geek Extraordinaire
        • Dec 2007
        • 3944
        I've heard of similar issues where the web firmware was not "up to speed" so to speak, with the rest of the machine.
        The version it has was valid, but didn't match the level of its cousins.
        I had an Autostore install a few years back that was similar, on a brand new 03 machine. The setup shop flashed some, but not all of the pieces, and Autostore refused to install. Once it was all on the same proverbial page, life was good. Possibly unrelated, possibly not.
        About 12 years ago, I had an issue with some new Canon machines. In that case, the webpage (or, "RUI" in Canon speak), was a version behind, and it failed to even open until flashed.
        • guitar9199
          • Sep 2016
          • 1100
          Try logging in as Administrator and then add Address Book entries.... if you're still getting the error, you might need to update the WEB UAPL FIRMWARE. Latest version is v1.04.5.
          • mikadonovan
            • May 2008
            • 2931
            I just updated firmware to the latest and greatest including webuapl, no joy. I checked the wim function sp modes, nothing is disabled or restricted. Sigh.
            Update: The problem is with Chrome. I just tried Firefox again with the updated firmware and it now will allow me to add addresses, Chrome will not.
            Thanks for all the input guys. I think I will head to the homestead on that note. Have a great weekend.
            • Tonerbomb
              AutoMajical Resolutionist
              • Feb 2005
              • 2589
              Mika try formatting the hard drive then initialize the address book with 5846. Had a unit a while back that a tech replaced the hard drive and when I entered a new user from the wim it didn't show in user tools and vise versa.
              Mystic Crystal Revelations
              • omorales
                • Mar 2015
                • 86
                try from the operation panel.
                  • 37493
                  There are SP settings that might be incorrect.
                  SP 5416
                  SP 5846-041 Execute to make address book accessible on a new HDD
                  SP 5846-050 Initialize all address books
                  SP 5985 Should be set to 1 if set to 2 will cause problems in WIM
                  • mikadonovan
                    • May 2008
                    • 2931
                    I tried an update to Chrome with no success. I had to reinsatall the browser to get it to work right, but all is good now..
                    • sharpmind
                      • Sep 2009
                      • 478
                      Try to go ADMINISTRATOR TOOLS---EXTENDED SECURITY...I think address book is in PROHIBIT mode.
                      • Polarbear
                        • Feb 2012
                        • 1070
                        You may experience Address Book errors like that if Service mode lock is active.
                        We had an MP4002 to the exact same thing this morning, and it turned out to be service mode lock that was switched on. "404 Not found" was the result, until we turned off service mode lock, then all was well.
                        Press the GREEN button!!
                        • mikadonovan
                          • May 2008
                          • 2931
                          Problem has been resolved, thanks for the input, guys.
                          • anothertech
                            • 1770
                            Don't leave us hanging. What was the solution?
                            • totoro
                              • 568
                              As he stated in earlier posts.... Originally Posted by mikadonovan
                              Totoro
