Cyan blotches on print Ricoh Pro C900
  • tjoppru
    • May 2025
    [Misc] Cyan blotches on print Ricoh Pro C900
    We are getting Cyan blotches on our prints. I have attached two samples. What can I do to fix this? Thanks in advance.
  • mbolduc
    • Jun 2015
    • 53
    Re: Cyan blotches on print Ricoh Pro C900
    exact match on spots on both sheets, check and clean cyan drum and/or transfer belt. If you aren't a tech call one.
    • tjoppru
      I cleaned the image off the image drum and transfer belt but it is still appearing on the prints just not as dark as before. Is there anywhere else the image could be stuck?
        • 37110
        Replace the drum.
        • anothertech
          • 1757
          That seems like a lot of machine to work on for someone asking questions on basic copy quality concerns. Are you the print shop owner trying to save a few bucks by doing your own maintenance?
          • tjoppru
            Having trouble finding someone in our desolate area willing to work on it. So I do what I have to do.
            • sturmtrooper
              Copier Combobulator
              • May 2016
              • 587
              Looks like there is damage to the surface of the drum. That spot on the drum is probably scraped down some which means the cleaning blade can't clean the toner off anymore. So when the drum runs over the paper the toner that wasn't cleaned off transfers to the paper.
              If the drum is damaged all you can do is replace it.
              • anothertech
                • 1757
                Try swapping the cyan drum with the magenta drum to see if the problem moves to magenta.
                If it moves to magenta, try waxing the drum, just to get you by till you can get a new one.
                • Tonerbomb
                  AutoMajical Resolutionist
                  • Feb 2005
                  • 2589
                  I would suggest you find someone to donate you a copy of the TCRU manual for operators.................
                  Mystic Crystal Revelations
                  • tjoppru
                    Thank you everyone for your suggestions. I replaced the cyan drum but now I am getting error SC477 so I can't tell if I fixed the problem or not. I can't seem to find that error anywhere on the code lists. I tried to get into clear the errors but it won't let me with the clear modes - 107 - Red button sequence. Does anyone have any ideas?
                      • 37110
                      Have you tried either the Service Manual, the Trouble Shooting guide or Goose's Guide? It is in all three.
                      • Gary Bowen
                        Bowdog
                        • Mar 2008
                        • 250
                        SC 477 PTR Motor Lock Error. Most common cause is a Bearing(s) in the PTR that are seizing up. You may want to follow the earlier advice in the posts and have this machine serviced by a TRAINED TECHNICIAN. This is too much machine for non professionals. I for one do not like working on machines that non contract customers have done any maintenance or repair to. These clients typically blame the tech for problems he has no control over (like replacing a OPC Drum and then the machine spits out a SC 477 error).
