mpc 2030 error
  • thi�n thanh
    • 11
    [Error Code] mpc 2030 error
    Hello friends
    Mpc 2030 Ricoh color error (see photo attached). People can give me solution
    thanks a lot
  • copier tech
    • 8164
    Re: mpc 2030 error
    Clean the density sensors then first run SP2111-03(c) followed by Sp2111-01(a)
    They try ACC again.
    • thi�n thanh
      • 11
      Re: mpc 2030 error
      They try ACC again.
      I'm done. sp 2111-01 (a), sp2111-02(b) error,sp 2111-03 ( c) complete
      there any other solution?
      thanks
      • copier tech
        • 8164
        Re: mpc 2030 error
        thanks
        Try again in the order I said above, C FIRST then A (ignore B)
        • thi�n thanh
          • 11
          Re: mpc 2030 error
          The first set 2111-03 (c). Next 2111-01 (a). final 2111-02 (b)
          the right order?
          • copier tech
            • 8164
            Re: mpc 2030 error
            the right order?
            • thi�n thanh
              • 11
              Re: mpc 2030 error
              Does it cause by " laze"? what does the" try again acc" mean? Can you explain more?
                • 37513
                Re: mpc 2030 error
                Did you clean the image density sensor assembly before running forced line position as copier tech said in his first reply? If the sensor is dirty or bad, line position will fail. See the attached bulletin for the proper procedure for cleaning the sensor. As it says in the bulletin, do not use alcohol to clean the sensor.
                rfg050980.pdf
                • thi�n thanh
                  • 11
                  Re: mpc 2030 error
                  [ATTACH]34669[/ATTACH]
                  you want to say to the sensor fails ID will make the defective color bar. (Please see attached photo)
                    • 37513
                    Re: mpc 2030 error
                    YES!!! And frequently just properly cleaning the sensor will correct the problem.
                    • thi�n thanh
                      • 11
                      Re: mpc 2030 error
                      I'll check back. thank you very much
