Mpc4502 fuser clack on start up
  • techsass
    • Dec 2010
    • 248
    #16
    Re: Mpc4502 fuser clack on start up
    Without firmware I'd go with Elmo's suggestion. Had a tech do a Sp5801-all years ago that caused it. Ricoh had me change the Pressure Roller timing & it went away. They did a firmware to fix it, but the manual Sp setting got rid of it before that came out.
    • mrfuser
      • 1617
      #17
      Tried Elmo idea to no avail. Odd it happened after replacing fuser. We swapped the fuser again and it still does it.
      • techsass
        • Dec 2010
        • 248
        #18
        Bummer. Was so long ago that I can't remember which Sp or the setting, but it was Pressure Roller timing. Checked & that's what Sp1151 is about. I'd pull out the Birth Cert. & play with the 1151 -2~-5. Since you've replaced the Fuser, I can't see it being a wallowed out gear on both.
        BTW the Default for Sp1151-5 is 220. It's the pressure release timing. I'd try lowering that first, since all the other motor timings are for adding pressure. Position 1 is 400; position 2 is 660 & position 3 is 2130.
        Good luck
