MP2852 language settings
  • GeorgeBest
    • Jul 2009
    • 526
    Hi,
    Updated the firmware, now I can only choose between English and some chinese language.
    How do I set up to switch between Englih and for excample Dutch ?
    Is this an SP mode ??
    Someone ?
    Thanks in advance
  • HDSB
    Field Tech
    • Feb 2013
    • 64
    Re: MP2852 language settings
    You will need to load the dutch language firmware, you've overwritten it with the Chinese one!!
    • copier tech
      • 8174
      School boy error!
        • 37533
        When you reflashed the Language firmware it should have given you the option to select a language. On some models it only shows one language module on the firmware update screen, with these models it will ask to select 2 (or more if the model supports more than 2) languages. If there are 2 languages modules shown, you must update both and select the language for each.
        • GeorgeBest
          • Jul 2009
          • 526
          Thnx Mate!
          School boy error!
