Re: MP2852 language settings
Thnx Mate!
When you reflashed the Language firmware it should have given you the option to select a language. On some models it only shows one language module on the firmware update screen, with these models it will ask to select 2 (or more if the model supports more than 2) languages. If there are 2 languages modules shown, you must update both and select the language for each.Leave a comment:
You will need to load the dutch language firmware, you've overwritten it with the Chinese one!!Leave a comment:
Updated the firmware, now I can only choose between English and some chinese language.
How do I set up to switch between Englih and for excample Dutch ?
Is this an SP mode ??
Someone ?
Thanks in advanceTags: None
