MPC305spf - Paper jamming in the Paper Transfer Roller Assy.
  • dave w
    • Jun 2015
    • 230
    [Jamming] MPC305spf - Paper jamming in the Paper Transfer Roller Assy.
    Can anybody please help?
    have you seen this problem on a MPC305 below
    paper from Tray 1/Tray 2 or bypass does the same, the paper rolls round the Transfer Roller and jams every time.
    A new Paper Transfer Roller has been fiitted and wrongly spspected.
    Any ideas please?
    Thanks in advance
  • gkalman2004
    • 157
    Re: MPC305spf - Paper jamming in the Paper Transfer Roller Assy.
    [ATTACH=CONFIG]34741[/ATTACH]
    Any ideas please?
    Thanks in advance
    The paper cling before arriving here probably you have something in the vertical transport what bend the corner of the paper.
    • Counsel
      • Aug 2011
      • 529
      2 things with the PTRs on those first is make sure its installed correctly, it should fit loosely into place not snug, if its snug then the mylar part is up over top of the bottom plastic and not down inside, these will clip into place even if the bottom edge is over top of the plastic. Secondly there is known issue with the mylar surface on them, it will crack in several spots and paper will catch on the mylar cracks and it will need replaced.
      • copier tech
        • 8192
        Looking at your picture it looks like you have not got the PTR fitted correctly, this is the one im working on now, see how it goes under the black guide.
        • dave w
          • Jun 2015
          • 230
          BIG thanks for the help.
          copier tech
          Hi - your right the pic does show that the unit isnt seated correctly, the paper that is jammed in it pulled it out when I opened the door to check.
          We have a mpc306 here that I did a visual comparison check with and all looked identical.
          Counsel
          Hi - have just checked the Mylar and all looks good, no cracks and is not creaced.
          Will try a new Mylar just in case there is something im missing.
          When the paper jam happends it doesnt always have a dog ear. sometimes all the leading edge is jammed in the unit. no nics to indicate it had catched on something first.
          I did a flow stop where I started the print and quickly opened the door to stop the machine. no indication of any interfierence with the leading edge passed the mylar.
          Looks like the problem is found. A broken Image Transfer Belt, The left hand side has a clean break.
          broken side
          right side has the unbroken part
          strange how the broken part was not found? bet the customer jus binned it without telling me.
          hope this is helpfull going forward if anybody else has a similar issue
          • TonerMunkeh
            Professional Moron
            • 3865
            That's interesting. That bracket looks to have a similar function to the D029 6318/6319 clips on the Apollon, camming the PTR into the correct position against the belt.
            Hit it.
            • dave w
              • Jun 2015
              • 230
              Yes thats what it does. Not been doing copiers that long (3 years) so still a baby at 53years old!
              • Counsel
                • Aug 2011
                • 529
                Glad you found the problem, and thanks for posting your fix for others to see.
