ricoh mpc 2051
  • tullio
    • Feb 2012
    • 268
    ricoh mpc 2051
    IMG-20161114-WA0000.jpgIMG-20161115-WA0001.jpgHe does not attack the toner. Print Meter 14000 black and white 23000 colore.urgente. thank you so much.
  • skynetto
    • Sep 2012
    • 257
    Re: ricoh mpc 2051
    Use oem toner.
    • TonerMunkeh
      Professional Moron
      • 3865
      Re: ricoh mpc 2051
      Originally posted by skynetto
      Use oem toner.
      Indeed. Replace the developer units and use original toner, NOT compatible. If you don't, your prints are crap.
      Hit it.
      • tullio
        • Feb 2012
        • 268
        Re: ricoh mpc 2051
        same problem ???????????? toner original
        • copier tech
          • 8174
          Re: ricoh mpc 2051
          Looking at your samples it looks like you have a fuser issue, what paper weight are you using? & have you set this in user tools, tray paper settings?
          Also update the firmware if it still is on original factory.
          Then run full music & ACC
          • eddy out
            • Oct 2016
            • 359
            Re: ricoh mpc 2051
            How thick is the media? It appears as though this is a thick paper running as regular paper.
            • tullio
              • Feb 2012
              • 268
              Re: ricoh mpc 2051
              paper 80g.
