Ricoh C3500 / Savin c3535 --- Scan to Folder or Email
    • 37553
    #31
    Re: Ricoh C3500 / Savin c3535 --- Scan to Folder or Email
    Originally posted by Elmo
    To be able to download it you would need the File Format Converter Option installed in the machine
    Not entirely so.
    If the file is scanned in using the scan portion of the document server or sent to the C3500 using print to document server then it will be in the compressed format used internally by the C3500 and the file format converter is required.
    On the other hand, if the fie is scanned into the document server using the Store File option on the scanner function it is saved in the format selected in the scan settings. I had a customer who used this all the time. They found it by reading the operators manual.
    • Mark Bbb
      • Jun 2012
      • 1662
      #32
      Elmo,
      so I did... But it won't work: "can not find printer- of copier-files" is the message...
      I have read the manual of the doc.server, indeed it tells me to install file format conv., but that's all the info there is.
      Anyone?
      • Elmo
        • Feb 2010
        • 541
        #33
        Nice 1 slimslob you live and learn
        just tried it on an mpc2800 works great
        Select scan button
        at top of screen select store file
        select store to hdd then scan document
        at pc web browse to machine
        click on document server
        on scanned item click on PDF (doc type)
        it opens it in a new window then right click you can save as
        or click on details it will then show info and give option to download
        I Used To Live To Fix Things Now i Fix Things To Live
        • qbert69
          • Mar 2013
          • 1152
          #34
          Re: Ricoh C3500 / Savin c3535 --- SMB PORT!!!
          It is fine and dandy if you upgrade to a custom firmware...
          BUT!
          I believe that Windows 10 uses port 445 instead of port 139 for SMB scanning!
          ...and as Ricoh shit goes, you'll have to telnet into the machine to change the port number!
          Change the priority port procedure of the SMB client:
          1) Connect to the target device by using telnet from the command prompt and log in as the administrator.
          2) Enter the following command:
          >smb client port 445
          RICOH Maintenance Shell.
          User access verification.
          login: ***** (enter the Administrator login name)
          Password: (enter the password)
          User access verification ... OK.
          RICOH ********
          Network Control Service Ver. 12.78
          Copyright (C) 1994-2016 Ricoh Co.,Ltd. All rights reserved.
          msh>smb client port 445
          msh> smb
          Workgroup Name : WORKGROUP
          Computer Name :
          Comment :
          Notification : Off
          Protocol : IPv4
          Client Port : 445
          Client Auth Level : 0
          Client WSD Browse : Off
          Client Write Mode : Async
          msh> logout
          Logout Maintenance Shell.
          Do you save configuration data? (yes/no/return) > yes
          Yes.
          Now, Save data.
          REACH FOR THE STARS!!!
          Konica Minolta Planetariums!
