MP 4001 SC995 ERROR
  • Stetner
    • Nov 2016
    • 23
    MP 4001 SC995 ERROR
    Hi all, I have spent many hours searching for answers to this problem to no avail. I have learned this is a serial number mismatch, but I can't find how to solve it.
    Back story: This machine worked perfectly with the exception of the ethernet port. Could not get it to connect to the network. I ordered a main board on ebay to
    hopefully fix the failed ethernet port. The replacement board matches the existing one exactly, but upon powering up the machine the red dialog appears with
    SC995. It won't allow me access to much, and I can't find any info on how to solve this problem. I know it is probably is a serial # mismatch with the new controller
    board but how do I reach the screen to enter the correct information?
  • tnelson
    • Aug 2016
    • 21
    Re: MP 4001 SC995 ERROR
    ok ... by main board do you mean the controller or the bicu?
    • Stetner
      • Nov 2016
      • 23
      Please excuse my ignorance lol....not sure which is which. I replaced the board that is mounted in the pullout rack that has the ethernet port on it.
      It also has the SD card slots, the memory module and HDD attached to it.
      • Stetner
        • Nov 2016
        • 23
        It is the board mounted in the slideout rack that has the Ethernet, SD slot, memory module and HDD mounted on it.
        • Elmo
          • Feb 2010
          • 541
          If you read thru the service manual it will explain how to get into service mode
          and also the procedure you must follow when replacing boards
          i advise you to get help from a qualified tech
          I Used To Live To Fix Things Now i Fix Things To Live
          • Stetner
            • Nov 2016
            • 23
            We are located in a rural area, so certified techs are not readily available. This is an old machine no longer covered by a service contract. We would like to
            save it from the landfill if possible. I don't have access to the service manual for this machine, and have had little luck finding it online.
            • tonnerboy
              • May 2011
              • 212
              MP4001 is not so old!!!
              A certified tech will solve your serial number problem
              • Stetner
                • Nov 2016
                • 23
                **Update... I found the info on how to enter the service menu, the serial number did need changed to match the number of the machine.
                I changed it and re-formatted the HDD, but the SC995 error is still present.
                • Stetner
                  • Nov 2016
                  • 23
                  If everyone's answer on here is to hire a certified tech, then what is the purpose of this forum?
                  • sturmtrooper
                    Copier Combobulator
                    • May 2016
                    • 587
                    Mostly for techs to help other techs.
                    • Stetner
                      • Nov 2016
                      • 23
                      OK point taken, I'll go elsewhere for answers. Thanks for nothing.
                      • Gary Bowen
                        Bowdog
                        • Mar 2008
                        • 250
                        Are you sure you have the right Controller Board? D0925724 is for the MP 4001 and D0925714 is for the MP 5001. The boards are not interchangeable and eBay is no guarantee that you got the right PCB. SC995 will not clear if it is the wrong board.
                        • Wild Bill
                          • Jul 2005
                          • 774
                          What a little snowflake, maybe you need some how chocolate...hmmmmmm?
                          Izzy
                          • mbolduc
                            • Jun 2015
                            • 53
                            RAM from old board should be moved to the new board
                            • Stetner
                              • Nov 2016
                              • 23
                              Now you want to resort to name calling? I'm fine that this forum is not for me....If you don't want to help me that's fine too.
                              But why do you need to call me a snowflake? How adult of you.
