Ricoh MP 3500 waste toner box full
  • Woody214
    • Oct 2015
    • 29
    How do you reset this message on the Ricoh MP 3500? Does not appear to have a waste toner container in this machine. Appreciate your help!
  • sandmanmac
    • 3985
    Re: Ricoh MP 3500 waste toner box full
    You empty it from the transfer belt container.
    Any service manual for this series dating back to a 1035 from the year 1999 (or so) would tell you this
      • 37560
      Actually back to the A230 series models. Introduced in June 1998.
      If the box is empty but the display still does not clear, the sensor is bad. To turn it off while waiting for a new sensor, use SP 2960. Do not leave it off on a permanent basis unless you plan to make regular trips to the customer to empty the box.
      • Bantams
        • Jun 2012
        • 603
        I always turn em off just check it on all visits only takes a few minutes to vac it out the sensors are too sensitive and can give false full reading even with the shitty bit of plastic they added to the blades to clean it
          • 37560
          Are you aware that vacuuming will blow the sensor.
          • TonerMunkeh
            Professional Moron
            • 3865
            With these abominations you'll be visiting to replace the developer WAY before the waste gets full.
            Hit it.
            • Counsel
              • Aug 2011
              • 529
              hehe i guess if he turns them off, blowing them out wont matter much.
                • 37560
                He most likely turns them off because he has already blown them.
                • Bantams
                  • Jun 2012
                  • 603
                  I don't vac the sensor that would be stupid lol
                    • 37560
                    If you vacuum the box at all you run the risk of creating enough static to blow the sensor. You also fill up your vacuum filter. Just dump them in a plastic waste basket liner. I have cats. I therefore have plastic buckets with lids that the cat litter comes in that 4 gallon bags fit purrfectly. Once I dump a waste toner, I snap the lid back on. Depending on the machine, I can get anywhere from 2 to 5 machines in one bag.
                    • Oze
                      Ricoh Fanboy
                      • Jul 2008
                      • 1663
                      Purrfectly...I see what u did there
                      • Iowatech
                        Not a service manager
                        • 3930
                        Does Ricoh still send the developer disposal bags with new developer orders? I used those for emptying used toner in all the time and they worked great. I think I've still got some of them out in the stealth van.
                          • 37560
                          Yes.
                          Ricoh parts used to put parts in long plastic bags fro shipping. Those bags were ideal for the 35/45 and 40/50 models.
                          • mbolduc
                            • Jun 2015
                            • 53
                            If the waste toner isn't full with message, you can clean the sensor with a rag. They are old school piso sensors.
                            • tec7
                              deactivate the toner full sensor. 2960* Toner Overflow Sensor [0 = No, 1 = Yes]
