Scan to email over SSL
+ More Options
Posts
  • tonnerboy
    • May 2011
    • 212
    #16
    Re: Scan to email over SSL
    Hello.
    I had na issue with na MPc3001 to use Office365 in last week.
    I found this info on TIER Answer ID 181362:
      • 37583
      #17
      Originally posted by tonnerboy
      Hello.
      [ATTACH=CONFIG]35006[/ATTACH]
      You might find this helpful.
      • tonnerboy
        • May 2011
        • 212
        #18
          • 37583
          #19
          No, it has to done to the machine. WIM needs to be used to install a certificate to the machine.
          • tonnerboy
            • May 2011
            • 212
            #20
            You are saying that the MFP will generate the certificate? Isnt that certificate for the WIM?
            (I am sorry if I am confusing everything...)
              • 37583
              #21
              No, the MFP does not generate the certificate. If you read the Knowledge base document I posted, you are copying a certificate extracted from your browser to the MFP. You are confusing site certificate with device certificate.
              • tonnerboy
                • May 2011
                • 212
                #22
                So what you telling me is that we should generate a certificate, according to the instructions you shared, for any connection that makes use of SSL / TLS. Yes?
                  • 37583
                  #23
                  No,you are not generating a certificate. The certificate already exists on your browser. You are just exporting from the browser to a file and then transferring it to the MFP.
                  • tonnerboy
                    • May 2011
                    • 212
                    #24
                    Hello.
                    I will try to explain the results performed in the tests.
                    After the instalation of the certificate following the procedure that you sent me, I was able to conect to the server only using the SMTP standard port 25. When I enable the "Use Secure Connection" it vanish the field of the comunication port number and it does not work... I think in this models (MPc3001) it uses the standard port 465 (SSL) when we enable the "Use Secure Connection" and we need to use 587 (TLS).
                    Even thow I was able to connect using Port 25 i could not send the attachment. It shows the message "enable to connect with the server...".
                    Like I said I think in this models (MPc3001) it uses the standard port 465 (SSL). Is there a way to change it to 587 (TLS)? Like for instance via Telnet?
                      • 37583
                      #25
                      Hello.
                      Try changing the port to 587 before enabling secure connection.
                      • tonnerboy
                        • May 2011
                        • 212
                        #26
                        I'd just like to ask you a simple question.
                        I took a look at the advanced options of the certificate and I was in doubt if I did not have to activate the checked options.
