ODD jams upon wakeup from sleepmode
  • fshead
    • 2376
    hi
    I have a MPC2800 wth 500k that i just rebuilt all feed stations and
    customer tells me sometimes at nite the machine will "wake up" to
    recv a fax and show a phantom jam...no paper stuck and machine works
    without issue all day..
    i did ck GG and saw nothing on this..
    have not gone to account yet but any ideas?
    firmware?
    not sure the latest on this series as i am not ""ricorico"..
    thnx
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: ODD jams upon wakeup from sleepmode
    Does it have a finisher? If so, bridge unit switches. If not, try firmware.
    Hit it.
    • fshead
      • 2376
      thnx
      no finisher,nor paper deck or bypass open..
      When you say firmware are you saying system,engine or fax FW?
      • LNorris
        • Sep 2008
        • 645
        what is the smc report saying on the jam?
        can you put it to sleep and duplicate jam when a print job sent to it so that you are there when it happens?
        • Counsel
          • Aug 2011
          • 529
          The smc should give you a jam location and time etc. Phantom jams wheres there no paper in the machine is usually a misfeed from the tray, which tray is designated for fax prints, or a power on jam which could be a door switch, i have found several times the push switch on the right hand side will get gummed up and cause door open for just a second which is a enough to interrupt the machine, you can usually spot this by pushing in on the right side door while its closed wiggling the door will cause the machine to beep like you just opened and closed it.
          I would check those and get the smc info to see where its saying its jammed.
            • 37556
            The SMC printout will show you the location, time and total for the last 10 jams. Display SP 7507 for the jam at the time you are interested will also show a code for the paper size. If you are getting a trail edge jam being shown on the SMC report, all received faxes on the fax journal are there and the print on the page received during the night is either rotated 90 or reduced, the paper size switch(s) might be going bad.
              • 23010
              I've seen this sort of jamming in environments that are not temperature/humidity controlled. If it's cool and humid, moisture will collect in the top pages in the paper tray, and on the fuser guides. The paper either never makes it out of the tray or sticks in the moisture on the guides before the fuser, and never makes it in.
              If this is the case, you might try to convince the enduser to locate the machine in a heated area, or to leave the temperature above 60F. Another solution that worked for one of my customers was to wake up the machine 1/2 hour before using it in the morning. Naturally that won't help for those overnight faxes. Maybe you could forward those to email instead?
              It would help a great deal to know the jam codes. =^..^=
              • fshead
                • 2376
                thanks all
                I have them using their old 3228 for faxes as i had parts on order for a different machine and they were ok
                with waiting till next week..
                I am leaning towards firmware or doorswitch as this office is in midtown building on the upper floors so machine stays warm and cozy
