Mpc4502
  • tavorh
    • Sep 2016
    • 25
    Mpc4502
    Hello,
    i have a problem with slight striped gray background, but test print (1103) is OK. Lines are stronger in full color print or copy. Sometimes gray lines almost already (are not visible), but later again returned.
    • 37556
    Re: Mpc4502
    Originally posted by tavorh
    Hello,
    Printer SP 1103-001 or SP 1103-002?
    Can you scan us a sample?
    • anothertech
      • 1771
      Re: Mpc4502
      What have you checked so far? Clean the slit glass for each color and clean the ITB cleaning unit.
      How does it look if you print or copy one color at a time?
      • tavorh
        • Sep 2016
        • 25
        Re: Mpc4502
        It makes grey vertical stripes in the background. Test print(1103) is perfect.
          • 37556
          Re: Mpc4502
          I do not see grey stripes in the background. I see an overall cyan background with magenta stripes.My guess is that you have a problem with the lifting mechanism for the color transfer rollers in the ITB.
          • tavorh
            • Sep 2016
            • 25
            Re: Mpc4502
            Thenks. I'll check it, bat when i print 1200x1200 don't have any problems.
            • Counsel
              • Aug 2011
              • 529
              Re: Mpc4502
              If they do not show up on a printed page but you get them making copies then clean your optics, in b&w mode you will get grey but in color mode dust on the optics could show up in any color depending on the density of the dust and how much light is reflected or absorbed. At 160k if your seeing this in print mode i would replace the itb cleaning unit and check your cyan and magenta drums you can remove the charge roller and lube bar from the bottom with a couple screws, you can vac out the lube bar chunks and clean the charge rollers.
              Like slim said though you can check the itb unit itself i had several of the itbs have issues on that model
