Ricoh MP C4500 not printing and no web access
  • xlanjeje
    • Dec 2016
    • 6
    Hello
    i just got a used Ricoh MP C4500 in donation with pump problems( black pump was defective so i order one in china).
    i just made a few prints before black toner was empty : i was able to install the printer and wrote test pages without any problem.
    i don't remember if web access was ok because i didn't test it.
    I made a few search about my new toy ( i mean the printer ) while waiting for my black pump and found the codes to enter service mode ( you know yellow button + 107 + hold c button )
    So i decided to explore this service mode and as far as i remember i didn't change anything.... ( i am sure i made something wrong , otherwise i would still be able to print , which is not the case).
    Here are the results now :
    1-Web access is not working anymore ( 404 error thru lan or directly connected to my pc via ethernet)
    2-No error message at printer startup but no printing is allowed because printer is offline ( third physical button on the printer where you can select which paper case you want to use , it says OFFLINE and there is no way you can activate ONLINE, it comes back to OFFLINE )
    3-i have check a few things before posting
    -SP5-828-091 is "1" (ON)
    -User tools / System settings / interface settings / permit ssl/tls communication/ set to "clear txt/cyphertext
  • mikedci
    • Jul 2010
    • 227
    Re: Ricoh MP C4500 not printing and no web access
    Print/scan on those machines is on an sd card in slot 1. I'd start by checking that. HDD and Ram(should be 1024) ok?
      • 37558
      Print the SMC Diagnostic Report SP 5990-005. Check if printer and scanner firmware versions are shown.
      Change -User tools / System settings / interface settings / permit ssl/tls communication/ set to "Ciphertext Priority"
      • xlanjeje
        • Dec 2016
        • 6
        hello
        thanks for your advice ( i am a real beginner in printer )
        I found a sd card in slot 1
        you will find a screen of all folders of sd card .... i don't know exactly what i should look inside the sdcard.
        Btw , i didn't test hdd nor memory ... is there an easy way to do it ?
        once again , thanks for all
        @slimbob Print the SMC Diagnostic Report SP 5990-005. Check if printer and scanner firmware versions are shown.
        button EXECUTE stay dark for a minute and nothing happens ( no information printed or shown )
        • tonnerboy
          • May 2011
          • 212
          Check SP 5985 - 001 On board NIC must be set to 1
          You also can check SP 5985 - 002 for USB
          • mikedci
            • Jul 2010
            • 227
            If you cant print a diagnostic report 5990-005 can you print a counter page?
            Check sp 7403 for any sc codes that may have been logged but not displayed on the screen
            you said you could telnet in...try typing show at the telnet prompt and see if any protocols(ipp, lpr...) are disabled...
            • Iowatech
              Not a service manager
              • 3930
              This might be the stupidest post on your thread, sorry about that.
              But what operating system is your network using?
              That can be kind of important information with older machines like that. I don't know about Apple or Linux systems, but thanks to the security updates an old machine can be unusable in newer Microsoft Windows environments.
              • mrfuser
                • 1622
                Just curious, are you a tech or end user?
                • xlanjeje
                  • Dec 2016
                  • 6
                  @mrfuser i am just an end user . In fact, i am a network admin teacher in a training center for unemployed people. Most of computers and servers we use are donations from former students we had. We were given two Ricoh printer ( one MP C4500 and one MP C2050 ) i try to fix.
                  @iowatech we use Dell poweredge servers with 2008 R2 and VM with Hyper V. but as i told you in my first message, we had no problem to use the printer before i entered service mode so i think it's not os related.
                  @mikedci
                  msh> status
                  Printer status : Idle.(Low: Black Toner.)
                  Online/Offline : Offline.
                  Printer is not ready.
                  msh> show status
                  Common:
                  Mode: 0x01
                  Protocol Up/Down:
                  AppleTalk: Up
                  IPv4: Up
                  IPv6: Down
                  NetWare: Up
                  SMB: Up
                  Device Up/Down:
                  USB: Up
                  Ethernet interface: AutoNegotiation
                  Syslog priority: LOG_INFO
                  NVRAM version: 5
                  Device name: NRG MP C4500
                  Comment:
                  Contact:
                  Soft switch: 0x00000001
                  AppleTalk:
                  Mode: EtherTalk phase 2
                  Net: 0xff01
                  Object: RicohPrinter
                  Type: LaserWriter
                  Zone: *
                  TCP/IP:
                  Mode(IPv4): 0xff8009c0
                  Mode(IPv6): 0xffbd7bc0
                  ftp: Up (IPv4/IPv6)
                  lpr: Up (IPv4/IPv6)
                  rsh: Up (IPv4/IPv6)
                  diprint: Up (IPv4/IPv6)
                  web: Up
                  http: Up (IPv4/IPv6)
                  ftpc: Down
                  snmp: Up
                  ipp: Up (IPv4/IPv6)
                  autonet: Up
                  Bonjour: Up
                  ssl: Up (IPv4/IPv6)
                  nrs: Up
                  rfu: Up (IPv4/IPv6)
                  nbt: Up
                  ssdp: Up
                  ssh: Up
                  sftp: Up (IPv4/IPv6)
                  IPv4:
                  DHCP: Off
                  Address: 172.016.010.140
                  Netmask: 255.255.000.000
                  Broadcast: 000.000.000.000
                  Gateway: 172.016.001.001
                  IPv6:
                  Stateless: On
                  Manual: :: prefixlen 64
                  Gateway: ::
                  EncapType: DIX Ethernet II
                  Host name: RNPB53461
                  DNS Domain: DHCP
                  Access Control:
                  IPv4:
                  Access Entry[1]: 000.000.000.000 - 000.000.000.000
                  Access Entry[2]: 000.000.000.000 - 000.000.000.000
                  Access Entry[3]: 000.000.000.000 - 000.000.000.000
                  Access Entry[4]: 000.000.000.000 - 000.000.000.000
                  Access Entry[5]: 000.000.000.000 - 000.000.000.000
                  IPv6:
                  Access Entry[1]: :: - ::
                  Access Entry[2]: :: - ::
                  Access Entry[3]: :: - ::
                  Access Entry[4]: :: - ::
                  Access Entry[5]: :: - ::
                  Time server: 000.000.000.000
                  Time Zone: 60
                  Time server polling time : 60
                  SYSLOG server: 127.000.000.001
                  Home page URL1: http://172.16.1.140/
                  Home page link name1:
                  Home page URL2:
                  Home page link name2:
                  Help page URL:
                  NetWare:
                  EncapType: Auto
                  RPRINTER number: 0
                  Print server name: RNPB53461
                  File server name:
                  Context name:
                  Switch: 0x03
                  Mode: Print server
                  NDS/Bindery: Auto sense
                  Packet negotiation: Normal
                  Login Mode: File Server
                  Print job timeout: 15(sec)
                  Protocol: IPX IPv4
                  SAP interval time: 60(sec)
                  NDS Tree Name:
                  SMB:
                  Switch: 0x0e
                  Mode: Workgroup
                  Direct print: On
                  Notification : Off
                  Workgroup name: WORKGROUP
                  Computer name:
                  Comment:
                  Share name[1]: MPC4500
                  Protocol: IPv4
                  DNS:
                  IPv4:
                  Server[1]: 172.016.001.001
                  Server[2]: 000.000.000.000
                  Server[3]: 000.000.000.000
                  Selected IPv4 DNS Server: static
                  IPv6:
                  Server[1]: ::
                  Server[2]: ::
                  Server[3]: ::
                  Domain name:
                  ether :
                  DDNS:
                  ether : Off
                  WINS:
                  ether : On
                  Primary WINS: 000.000.000.000
                  Secondary WINS: 000.000.000.000
                  SSDP:
                  UUID: 03fc2f44-1dd2-11b2-9c68-a8bc7e9c571c
                  Profile: 10800(sec)
                  TTL: 4
                  UPnP:
                  URL:
                  Bonjour:
                  Computer Name(cname):
                  Local Hostname(ether):
                  Priority(diprint): 10
                  Priority(lpr): 20
                  Priority(ipp): 30
                  IP TTL: 255
                  LinkLocal Route for Multi I/F: Ethernet(ether)
                  SNMP:
                  SNMPv1v2: On
                  SNMPv3: On
                  protocol: IPv4 IPv6 IPX
                  v1Trap: On
                  v2Trap: Off
                  v3Trap: Off
                  SNMPv1v2 Remote Setting: Enable
                  SNMPv3 Privacy: Auto
                  ssh:
                  Compression: On
                  Port: 22
                  TimeOut: 300(sec)
                  LoginTimeOut: 300(sec)
                  LPR:
                  lprm check host: On
                  Certificate:
                  Verification: Off
                  Shell mode: User mode
                  thanks to everybody for your support
                  • xlanjeje
                    • Dec 2016
                    • 6
                    any help please ?
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Do an NCS clear and reset all the network side of the machine back to defaults. Gives you a good place to start from.
                      Hit it.
                      • mikedci
                        • Jul 2010
                        • 227
                        I'd also clear the printer and scanner. sp 5-801-008, sp 5-801-009
                        • qbert69
                          • Mar 2013
                          • 1152
                          Is it picking up an IP address in DHCP mode?....If so, try logging into the Web Monitor by using "https" instead of "http"!....some of these "used" machines are set to only be accessed in secure http mode!
                          REACH FOR THE STARS!!!
                          Konica Minolta Planetariums!
                          • guitar9199
                            • Sep 2016
                            • 1100
                            Sometimes the simple answer is usually the correct one...
                            Have you tried using a different browser? Sometimes IE/Edge are..... well, kind of stupid.
                            Have you tried using Google DNS settings on your computer instead of what the network provides? (8.8.8.8 Primary - 8.8.4.4 Secondary)
                            If nothing else, you could always try a System Reset.
                            Good Luck.
                            • xlanjeje
                              • Dec 2016
                              • 6
                              thanks to all you guys for your support , you are amazing
                              first reply from TonerMunkeh did the trick . All printing functions are now working normally . Wim is now working.
                              You guys save my day
                              Big thanks for all
