running 110 lb 11x17 cardstock doublesided on a mp c3001 full color?
  • fshead
    • 2376
    hi
    i just got a call back from a print guy trying to run 11 by 17 double sided full color on 110 lb card stock.
    I didnt see any fusing issued when i was there yesterday and just calibrated and did process control and showed
    him how to set up the 2 tray for card stock.
    from what i am hearing he is getting random ghousting from the fusing unit.\
    is this unit up to 110lb?
    i luckily dont deal wth too many print shops trying to perform magic with these copiers so any info is appreciated.
    this machine has less than 100k total copies
  • LNorris
    • Sep 2008
    • 645
    Re: running 110 lb 11x17 cardstock doublesided on a mp c3001 full color?
    from product support guide:
    Paper Type Capability Std Tray Plain Paper (No Display Paper Type),Recycle Paper, Special Paper 1-3,Color Paper, Letterhead, Cardstock,Preprinted Paper, Bond Paper
    Tray1: High-gloss coated paper
    Tray2: Envelope, Coated, High-glosscoated paper[Thickness]Thin Paper, Normal Paper, ThickPaper 1, Thick Paper 2, Thick Paper 3Bank,
    LCT Plain Paper (No Display Paper Type),Recycle Paper, Special Paper 1-3,Color Paper, Letterhead, Cardstock,Label Paper, Preprinted Paper, BondPaper, Plain Paper Backside[Thickness]Thin Paper, Normal Paper, ThickPaper 1, Thick Paper 2, Thick Paper 3
    Bypass Tray [Paper Type]Normal Paper (No Display PaperType), Recycle Paper, Special Paper1-3, Color Paper, Letterhead,Cardstock, Label Paper, OHP,Preprinted Paper, Bond Paper,Envelope, Coated, High-gloss coatedpaper[Thickness]Thin Paper, Normal Paper, ThickPaper 1, Thick Paper 2,Thick Paper 3,Thick Paper 4
    Paper Weight *3 Std Tray 60-25616 - 68lb.Bond - 140 lb.Index
    Bypass 60-30016 - 68 lb.Bond - 110 lb.Cover
    Duplex Unit 60-16916-45
      • 23010
      Originally posted by fshead
      hi
      There is no paper type cardstock. Is it 110# Bond, Offset, Cover, Tag, Index, Points, Caliper, or gsm (grams per meter squared)? Each is # weight is based on a different sheet size, and consequently are totally different paper weights.
      • anothertech
        • 1771
        110 cover should run, make sure to set the machine paper tray for that stock, no auto duplex for that. run second side through the bypass, again make sure the bypass is set for that stock. It's not really a very good machine for a print shop.
        • fshead
          • 2376
          thnx
          i am going back today,and did not see the exact heavy paper he was using.
          the extent of info i get from my customer here is the paper is good i got it from "Staples"...yeah...
          I am not one to start tweaking fuser temps but will if i have no choice.
            • 37560
            Make sure that both paper type and paper thickness are set properly. Too many set type to card stock but leave thickness set to Plain Paper. For 110 # thickness needs to be either Thick 3 or Thick 4.
            • fshead
              • 2376
              thnx I am heading there now.
              will update..watch now its probably not happening as i havent got my every hour phone call
              like yesterday asking when am i getting there...................
