SC 544 AFICIO MPC3002
  • luis_p712
    • Jun 2014
    • 9
    [Error Code] SC 544 AFICIO MPC3002
    Hello everyone, I have a mfp which I found with this code SC544 with the fuser unit in poor condition. Proceed to replace the entire fuser unit with another new one and reset the SC544. But I have not achieved either with the sp5810. Any suggestion, I will be grateful thank you.
  • gkalman2004
    • 157
    Re: SC 544 AFICIO MPC3002
    • Mark Bbb
      • Jun 2012
      • 1662
      check thermophile
      • john millington
        I was under the impression that once sc544 had been triggered you had to fit new fuse to fuser unit, This is supplied with a new sleeve assy.
          • 8182
          As John says with SC544 you need to replace the fuser sleeve & the quick blow fuse that comes in the box, then you can reset this high temp error with SP5810-02
          I have a few spare fuses so I can just fit a new fuse without ordering a new sleeve etc
            • 37542
            Unless it was a problem with the sleeve that caused the error.
