Pro C5100s Ghosting
  • barber782
    • Aug 2011
    • 286
    Pro C5100s Ghosting
    Happy new year all,
    Iv got a problem Pro C5100s which is ghosting\ repeating on normal 80gsm paper.
    Machine has done around 550k. PM was done in November last year and was working fine till now.
    Leaning towards a fusing problem, ie pressure levers.
    Has anyone else had this issue? Sorry no samples.
  • copier tech
    • 8237
    Re: Pro C5100s Ghosting
    As machine has only done 550k fuser & drums wont have hit PM life yet, my money would be on paper settings as sugested above. However if the machine has been run mostly on heavy paper the fuser may have worn out before PM is life.
    Post a few samples that would help, the fiery calibration print out or copier ACC page for example.
    • NeoMatrix
      Senior Tech.
      • 3513
      Quenching lamps ????....
      • barber782
        • Aug 2011
        • 286
        301 Moved Permanently
        Sample
        Sent from my GT-I9195 using Tapatalk
