Ricoh 2051 with shadow to next copy
  • rudysemira
    • Oct 2016
    • 108
    Hi everyone i need to solve my problem i replace the drum but when i use to copy the next paper with shadow followed from word this is a letter for example word apple the next paper with shadow the word apple any idea please give me some help... thanks
  • copier tech
    • 8178
    Re: Ricoh 2051 with shadow to next copy
    Posting a print sample would help.
    However if the image repeating is the same colour as the drum you replaced then I'd check the fuser condition.
    • Mr. Breaker
      • Nov 2014
      • 17
      In case of offset, change these sp modes:
      SP1 112 002, from -10 to => 0
      SP1 101 010 , 55 => 0
      SP1 101 014 , 55 => 0
      SP1 101 022 , 55 => 0
      SP1 101 026 , 55 => 0
      SP1 101 107 , 55 => 0
      SP1 101 111 , 55 => 0
      SP1 102 006 , 0 => 3
      Best regards,
      Mr. Breaker
      • jonhiker
        • 661
        check the condition of the fusing unit. a dirty or worn hot roller could also be the cause.
          • 37538
          First are you talking about the Aficio 2051 B/W machine or the MP C2051 color machine?
          If it is the B/W machine, did you replace the cleaning blade and cleaning brush? If so, did you use Genuine Ricoh parts or after market parts? I have had problems with after market cleaning blades being either too rigid and damaging the drum surface or to soft and not thoroughly cleaning the drum surface.
          • khattab.al.masry
            • 212
            I hope the following attachment will be helpful for you.
              • 37538
              I am the one who originally placed that .pdf on CTN. It will not help with off setting and definitely will not be useful on a B/W machine. It's main purpose is to reduce toner hazing and dirty charge rollers.
              • rudysemira
                • Oct 2016
                • 108
                thank you for your quicky response on my post now i solve the problem i am new for ricoh tech i have checked the fuser section and i saw the web cleaning roller was stucked up coz the gears was broken then the fuser roller also damaged so i replaced both parts.........
                • rudysemira
                  • Oct 2016
                  • 108
                  Best regards,
                  Mr. Breaker
                  Thank you Mr. Breaker for this info i use this for the future if i encouter just in case......my problem is from the fuser roller and the gears of cleaning web roller was worn out...
                  • rudysemira
                    • Oct 2016
                    • 108
                    thanks-this-will-be-help-for-my-reference-as-guide-for-troubleshooting....
                    • rudysemira
                      • Oct 2016
                      • 108
                      thank you this information....Sir
                      • rudysemira
                        • Oct 2016
                        • 108
                        Yes, you right sir it is dirty and worn out the hot roller...now its working..
                        • rudysemira
                          • Oct 2016
                          • 108
                          [QUOTE=slimslob;546625]First are you talking about the Aficio 2051 B/W machine or the MP C2051 color machine?
                          the machine aficio 2051 b/w .... i dont know the history about the machine coz the staff not telling the truth what is the previous problem so i replaced the drum. The problem before when i make a copy the density black is uneven or not balance the rear and front and also have scratches, so according to what i have read i replaced the drum and also the developer and i followed the instruction manual steb by step...for finalizing i make a copy and that problem appear....but now is working good i saw there is a problem also from hot roller and the gear from the web cleaning roller......thanks for this info..
                          • khattab.al.masry
                            • 212
                            With All My Pleasure And Respect I Admit.
                            • HitMan
                              • Aug 2015
                              • 170
                              User tools- maintenance- plain paper type- set this to plain paper type 2
