Ricoh C3500 - total newbie with dumb questions ;)
  • lilysdad
    • Jan 2017
    • 24
    [Misc] Ricoh C3500 - total newbie with dumb questions ;)
  • TonerMunkeh
    Professional Moron
    • 3865
    Re: Ricoh C3500 - total newbie with dumb questions
    A small list
    ALWAYS run original toner. Make sure the fusing belt, oil supply roller and cleaning roller are in good shape. Print off an SMC - SP5990-004 and check the PM counters. If the drums are over 80k, they will need replacing. 160k for the devs. With regard to the admin password, log in as "supervisor" with no password, go to System Settings / Admin Tools / Program/Change Administrator / Administrator 1 / Change Password. Leave it blank and make sure you press OK to come out of the settings, not the user tools key or this won't work.
    Also, print off a configuration page. User Tools / Printer Features / Config Page. Check "supported languages" at the top. You *may* be really lucky and it may have a Postscript card in it.
    Hit it.
    • lilysdad
      • Jan 2017
      • 24
      Thanks for responding! Where do I find the PM (preventative maintenance?) counters? SMC - SP5990-004
      No clue what any of this means:
      Printer Language: RPCS [3.3.25.1.2], PCL 5c [1.13], PCL XL [1.13]
      Also - is it really that bad to use 3rd party toner? I just ordered some the other day...
      • Boltaction
        • 92
        You'll be able to get in and print out your logging data by entering service mode
        Clear Modes - 1 - 0 - 7 - Clear/Stop key (hold key down until service mode appears)
        Then Copy SP
        Go to DataLog1 and then PM Counter Display
        Or you can go into Mode, SP Print and then Logging Data which will show your PM Counters and Jam History
        Good luck
        • mikadonovan
          • May 2008
          • 2931
          Usb printing is limited, if you hook it up to your network and use the Pcl6 driver you will have more options.
          NEVER ASSUME ANYTHING
          • copier tech
            • 8195
            As you got the machine dirt cheap I would spend a bit more on the machine & call out a Ricoh tech to give the machine a good service & clean a good tech will also update the firmware, even show you the basics to maintain it yourself in the future.
            This would be money well spent!
            • lilysdad
              • Jan 2017
              • 24
              Oh man... you guys freaking rock... for real!
              Can't change the admin login "You do not have the privileges to use this function"
              Total paper jam counter - 23 - I think I'm like 7 or 8 of these, lol
              Image Transfer Belt & Cleaning unit replaced at 70323
              Looks like it's still on the original CMY and I just installed the second K (3rd party..., ooops) as far as I can tell.
              It has like 160k total prints. I honestly think it was only used to print receipts/contracts occasionally for a small loan business or something...
              Was able to install the PCL6 driver and am using via USB - WAY more options - needed this
              You guys won't believe how much I paid for this thing.... $50! lol
              • lilysdad
                • Jan 2017
                • 24
                Any idea what that would cost? Know anyone in Atlanta that would barter or work for cheap? lol...
                • copier tech
                  • 8195
                  Start a new thread i'm sure you'll find a tech in Atlanta
                    • 37560
                    Try logging in to User Tools as supervisor with no password. The only thing that supervisor can do is change admin credentials.
                    As for the printing, does the does the finisher have a booklet stapler? If it does, there should be an option for booklet on the finishing tab of the driver preferences.
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      Unfortunately, yes. These machines don't like it and toner pump failures occur regularly.
                      Hit it.
                      • lilysdad
                        • Jan 2017
                        • 24
                        Thanks for all the great feedback everyone! Welp, I managed to blow up the USB control board in this thing - mistakenly plugged in the weird pronged power cord upside down, lol. Now time to find a used part I suppose to replace it.
                        Spent a little time in the manual and got it working over my home network now via Ethernet connected to my router, but it seems some of the better drivers aren't supported in that format.
                        ONE MORE BIG QUESTION if you'll all continue to appease me here! I'm having a tough time getting the paper to print dead center on 11x17. The side that feeds out of the printer last always has more margin (right hand side of paper) than the left side. It's minimal, but I'm making photo books with full page spreads. Any advice how I can correct this issue? On some of the pages you see the back side of another photo's gutter coming through slightly.
                        BTW - happens in both lower paper drawers and with all the various drivers I've tried. I'm putting 32 pound paper through it double sided, however it was still doing the same with 20 lb copy paper too. Any ideas how I can correct this?
                        Thanks for everything so far!!
                        • mikadonovan
                          • May 2008
                          • 2931
                          The procedure for adjusting the scanner and printer registrations are in the service manual. Just do a PDF search. Also, if you are copying, check the edit/color tab at the bottom of the screen and make sure there is not a margin set as default.
                          • lilysdad
                            • Jan 2017
                            • 24
                            Thanks for all the help so far! I'm actually learning a few things now
                            I started getting magenta streaking in various parts of the white paper - printing BIG images on 11x17 double sided. Also getting the occasional black blotch or specs as well. I took out both drums and cleaned the charge rollers (smooth, hard black roller, right?) as well as the foam cleaning rollers with it. It got better for a few pages and just came back again.
                            I just ordered two new drum units off ebay. B2232027 RICOH AFICIO MP C2500 C3500 DRUM UNIT COLOR | eBay
                            Anything else I should be doing right now that you all can think of?
                            • TonerMunkeh
                              Professional Moron
                              • 3865
                              I'd fit an ITB cleaning unit too. Make sure you make the appropriate change in SP3902 to tell the machine you're fitting the parts, then power off. The machine will set them up properly when it's switched back on.
                              Hit it.
