Ricoh C3500 - total newbie with dumb questions ;)
  • Oze
    Ricoh Fanboy
    • Jul 2008
    • 1663
    #31
    Re: Ricoh C3500 - total newbie with dumb questions
    The reason that the pumps fail isn't due to being clogged...it's more to do with the fact that the round parts inside the unit get worn into an oval shape.
    Using a second hand pump is never recommended for that very reason.
    You can easily swap the pump in from any color....we only order the black pump units these days as they fit each colour.
      • 37561
      #32
      Originally posted by lilysdad
      Alright - it's nice having USB back again finally.
      Replaced the black toner pump and it's doing it less now, but still happening. This was a used black toner pump off the other machine.
      Question - can I pull a toner pump from another call on the other machine and blow it out with compressed air and swap in as black or will that F it up? Don't wanna throw another $100 at this thing... lol
      The PCDU is the drum unit and development unit connected together. After removing the PCDU from the machine, you have to remove the front cover and a retaining clip and bushing from the back to separate the two units.
      • lilysdad
        • Jan 2017
        • 24
        #33
        The clicking noise has returned again and I keep getting repeated, false toner empty notifications on black. Pulled another toner pump and replaced it with another used one. Got a bit better, but still keeps happening repeatedly.
        It sounds like a gear or something on the back of the machine is trying to engage and struggling. What else can I do? Any direction is really appreciated!!
          • 37561
          #34
          Buy a NEW toner pump with tubing. With the clicking, by now you might also replace the gear that drives that toner pump.
          • Mark Bbb
            • Jun 2012
            • 1662
            #35
            As you got the machine dirt cheap I would spend a bit more on the machine & call out a Ricoh tech to give the machine a good service & clean a good tech will also update the firmware, even show you the basics to maintain it yourself in the future.
            This would be money well spent!
            I under scribe this reply very much.
            • lilysdad
              • Jan 2017
              • 24
              #36
              Good feedback - thank you - I'll post looking for one today!
              • lilysdad
                • Jan 2017
                • 24
                #37
                Thank you - will purchase a new one today! Does anyone have a PN# for the toner pump gear(s)?
                • qbert69
                  • Mar 2013
                  • 1152
                  #38
                  Genuine Ricoh BLACK Toner Pump B223-3255 B2233255 B223-3211 B2233211 C4500 C3500
                  REACH FOR THE STARS!!!
                  Konica Minolta Planetariums!
                  • lilysdad
                    • Jan 2017
                    • 24
                    #39
                    Thanks! I actually just scooped one up on eBay for $45 brand new B2233255 BLACK TONER PUMP | eBay
                    • TonerMunkeh
                      Professional Moron
                      • 3865
                      #40
                      Gears - AB01 0367 and 0368. Hope it's just the little one that's shredded that drives the dev unit. If not, it's a good chunk of the back of the machine out.
                      Hit it.
                        • 37561
                        #41
                        Did it include the toner tube?
                        • Raoufselwaness
                          Expert
                          • Nov 2008
                          • 75
                          #42
                          Thanks for responding! Where do I find the PM (preventative maintenance?) counters? SMC - SP5990-004
                          No clue what any of this means:
                          Printer Language: RPCS [3.3.25.1.2], PCL 5c [1.13], PCL XL [1.13]
                          Also - is it really that bad to use 3rd party toner? I just ordered some the other day...
                          If you use a KATUN toner it will be good as original.
                          • lilysdad
                            • Jan 2017
                            • 24
                            #43
                            So here's my latest problem, lol.
                            Getting a faint yellow line down the middle of the length of the page (11x17). Switched out drums as well as the image transfer belt and I'm still getting the problem. Vacuumed out the whole printer... not sure where to go next.
                            I'm also getting a lot of dirty, black spotty prints. Is this likely a drum issue?
                            Any help is appreciated!!
                            • lilysdad
                              • Jan 2017
                              • 24
                              #44
                              Here's an example:
                                Here's an example:
                                [ATTACH=CONFIG]35707[/ATTACH]
                                is that a copy or print? the line appears to be angled to me....
