Mpc5501 sc899
  • mrfuser
    • 1617
    Mpc5501 sc899
    Machine boots and as soon as comes to print ready goes into sc899. Cables unplugged even.
    any ideas how to recover this?
  • mrfuser
    • 1617
    Re: Mpc5501 sc899
    Well this is one for the books ! I remove the fax board in the machine popped up perfect ran great so it is a corrupted fax board !
    I hope this helps somebody else down the road because this is the dumbest thing I've ever seen
    • anothertech
      • 1769
      Re: Mpc5501 sc899
      Newest firmware should prevent this. Fax ver6.0 firmware, but update all firmwares for the machine to be sure.
      • tufbnme
        • 493
        Re: Mpc5501 sc899
        How about the HDD? Could be bad as well.
        • mrfuser
          • 1617
          Re: Mpc5501 sc899
          As I said it was a bad fax board. That's it
          • mrfuser
            • 1617
            Re: Mpc5501 sc899
            OK replaced fax board worked for about 10 minutes went back into code so something else is not happy with any fax board being in there
            • guitar9199
              • Sep 2016
              • 1100
              Re: Mpc5501 sc899
              I'd go back to updating the firmware, and see if that clears it up.
              ....couldn't hurt.
              • Xcelsior
                Ex-Tech
                • Jan 2017
                • 24
                Re: Mpc5501 sc899
                As has been mentioned, update the Firmware. SC899 is just a software error that any number of things can cause. Printing from a Browser causes it a lot and a PCL firmware updates mostly fixes that. It's possible for hardware to be the cause, but it's rare.
                In regards to SC899 on an MP C5501, some examples;
                System 2.04 fixed;
                SC899 occurs while the machine is scanning a document for to create a "HighCompression PDF" file.
                Printer 1.04;
                Anything that causes the MFP to NACK (Negative Acknowledgement) (such as a paperjam or staple/punch out of position) during the submission of an IPDS job might result inan SC899 error.
                Fax 6.0;
                SC899 may occur during FAX function is in use
                Plus several other issues fixed in other Firmware versions.
                Previous Ricoh Field Service Tech II - November 2017.
                • KenB
                  Geek Extraordinaire
                  • Dec 2007
                  • 3944
                  Re: Mpc5501 sc899
                  Not normally considered part of firmware, but make sure to update Java (if so equpped), too.
                  Even if you have no apps installed, Java can cause SC899.
                  We had that happen on a bunch of SP model printers (the exact model number escapes me), that kept throwing SC899.
                  Normally printers don't have Java, but these did, and they were purchased that way for future expansion.
                  Once we updated Java, the problem stopped. (Of course, that was after updating ALL the other firmware.)
                  • anothertech
                    • 1769
                    Re: Mpc5501 sc899
                    If it has a Java card, just uninstall it, you are probably not using it anyways.
                      • 37490
                      Re: Mpc5501 sc899
                      Just remember to go into user tools and stop JAVA. If you remove the JAVA card without first stopping JAVA, you risk cratering the controller board when you turn the machine back on.
