Ricoh MP 2051sp scan to folder problem
  • Azharuddin
    • Jun 2016
    • 33
    Hi everyone
    I'm facing scanning issue on this machine .
    It shows communication/transmission status is standby only. I checked with other machine the storage path and authentication all same. But when I tried to do a connection test it shows "connection failed,check the communication path" . The other engg told me to update the firmware and check.
    If firmware needs to be updated can anyone share the firmware file.
    Thanks in advance.
    Sent from my XT1562 using Tapatalk
    • 8164
    Re: Ricoh MP 2051sp scan to folder problem
    Yes this is a known issue, you'll need to update the firmware, especially network however it is always best to update ALL the files.
      • 37515
      Since you are getting the message "connection failed,check the communication path" is might not be firmware. Try going into the addressbook entry from the MFP control panel (not WIM) and do a connection test. If it connects but you cannot send, you need firmware. If connection fails, check that all your interface settings are correct. If domain name, workgroup, or DNS are not correct, the 2051 might not be able to resolve Netbios name.
      • Azharuddin
        • Jun 2016
        • 33
        For firmware update purpose what size of memory required?
          • 8164
          Any size sd card upto 2gb will be fine
          • Azharuddin
            • Jun 2016
            • 33
            Hi
            I updated the latest network firmware even though same like before .
            The same path and authentication used one more HP scanner. There it's working with out any errors.
            Thanks in advance
            • nadimtopsecret
              Experienced Tech
              • Mar 2013
              • 47
              You can temporarily stop " Firewall " & " Antivirus " (if there is any), then try again; I hope it will help you.
              • Azharuddin
                • Jun 2016
                • 33
                That is a server shared folder so they will not change any settings on that. Here They have HP ,Konica Minolta and Ricoh machines. Only in Ricoh it's not working. Thanks in advance.
                • tonnerboy
                  • May 2011
                  • 212
                  Hi.
                  Try to change the SMB port to 445 using telnet.
                  Telnet Comand:
                  >smb client port 445
                  >logout
                  >yes
                  note: there was a Windows update for Server environments that desabled the 139 net bios port for SMB...
                    • 37515
                    /What you need is Special/Custom Firmware B140_Network_Support_V4.18.2C_LRC0466 dated 7/1/2013. I do not know if it is available anywhere other than North America. It is not standard production firmware. The last production NCS firmware was released in 2007.
                    • James1409
                      • Oct 2015
                      • 10
                      Go to Control panel, select "Programs & Features". On the top left, select "Turn Windows features on or off"
                      Scroll down to "SMB 1.0/ File sharing support" and make sure it is ticked. Do a quick restart and hopefully you will be good to go.
                      See if this doesnt sort your issue.
                      • James1409
                        • Oct 2015
                        • 10
                        Go to Control panel, select "Programs & Features". On the top left, select "Turn Windows features on or off" Scroll down to "SMB 1.0/ File sharing support and make sure it is ticked.
                        • Debs1964
                          • Oct 2010
                          • 1693
                          I suspect this 4 year old issue has probably been resolved by now
                          There are 10 types of people in this world, those who understand binary maths and those who don't
                          • sandmanmac
                            • 3981
                            ...Not to mention that it's just plain bad and dangerous advice!
                            • James1409
                              • Oct 2015
                              • 10
                              I am so sorry for posting at all.
